To save many Jeepers the trouble of deciding where to source parts for their stroker, I'll make it easy by posting links for them. Summit Racing is the main parts source but you may need to buy some parts from other sources.
258 crankshaft: Ebay, 505 Performance, Hesco
Connecting rods: Reuse stock 4.0, 505 Performance, Hesco
ARP rod bolts: Summit Racing
Pistons & rings: Keith Black ICON, Hesco, 505 Performance
Main bearings: Summit Racing
Rod bearings: Summit Racing
Cam bearings: Summit Racing
Oil pumps: Summit Racing
Timing sets: Summit Racing
Camshaft & lifter kits: Summit Racing
Cam bolt, pin & spring: Hesco
Cam bolt washer: Hesco
Roller rocker arms: Summit Racing
Harmonic balancers: Summit Racing
Harmonic balancer spacer: Hesco
Freeze plugs: Summit Racing
Mopar Performance 5249464 valve springs: Summit Racing
Mopar Performance 4452032 valve spring retainers: Summit Racing
Mopar Performance 4529218 valve keepers: Summit Racing
Pushrods: Reuse stock 4.0, Hesco, Crower
Gaskets & seals: Summit Racing, Mopar Performance
Flowkooler high flow water pump: Summit Racing
Thermostats: Summit Racing
High flow thermostat housing: Hesco
Cylinder head bolts: Hesco 87-96, Hesco 97-06, Headbolts.com
Stroker Parts List
Stroker Parts List
boomerjeep
- Vehicle Year: 2002
- Vehicle Model: wrangler
Re: Stroker Parts List
your the man
GoMopar440
I vote this should be a sticky with as often as this question gets asked.
Great job Dino!
Great job Dino!
604rail_king
- Vehicle Year: 1995
- Vehicle Model: XJ
dino, are you getting residuals from every stroker part bought off summit
Falcon Global on ebay sells some of the same parts - most of which are for less than Summit or Jegs (ie: main/rod bearings)
boomerjeep
where is the best place to buy the 24# injectors?
He he, I'd probably be a rich man if I did.604rail_king wrote:dino, are you getting residuals from every stroker part bought off summit
- Muad'Dib
People can also look at the projects section and get a parts list. For example my project thread which has a nice parts list table:
http://www.jeepstrokers.com/forum/viewt ... f=8&t=2317
I am putting these posts in the FAQ.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 5 guests
