first stroker couple of questions computor settings
jeff3873
Post by jeff3873 »
Just built my first stroke engine following all the guide lines .It is a 1998 Jeep Wrangler and I have 2 questions is there any computor setting s that need to be changed I used the comp camand 24lb injectors.Second question oil pressure was fine for the first hour or so and now is dropping to 20-30 lbs at idle any suggestions ?
crusher242
Vehicle Year: 1999
Re: first stroker couple of questions computor settings
Post by crusher242 »
Are you useing a high volume oil pump? Might be the culprit. Also, just curious what injectors you went with. I have a 99' I'll be building for and I'm checking out all the options.
jeff3873 wrote:Just built my first stroke engine following all the guide lines .It is a 1998 Jeep Wrangler and I have 2 questions is there any computor setting s that need to be changed I used the comp camand 24lb injectors.Second question oil pressure was fine for the first hour or so and now is dropping to 20-30 lbs at idle any suggestions ?
Firstly, you can run the stock computer without modification,
Secondly, if that's the idle oil pressure when the engine's hot and it rises to 40+ psi when you rev it up to 2000rpm, it's normal. The oil pressure will be higher when the engine's cold.
20-30 lbs at hot idle isn't bad at all.
A HV oil pump wouldn't cause low oil pressure.
jeff3873
Post by jeff3873 »
Thanks and yes I am running a HV oil pump oil pressure cold at idle and running is 40 then drops to 20 when idling hot .I have 24 lb injectors installed and other then the oil pressure everything else is good.
Sounds like all is well.
jeff3873
Post by jeff3873 »
All is good with the oil pressure I installed a manual gauge and when cold pressure is 60 and then falls to 30 . Now after running it i have develope a slight miss when accelerating but not all the time it is very erratcic you can drive 30 miles it it might do it twice on acceleration any thoughts from anyone ?
Check your computer for fault codes.
