dieing 4.0 problem
gearhead1985
Vehicle Model: yj
dieing 4.0 problem
Post by gearhead1985 »
well i have a 92ish jeep wrangler with a dieing 4.0 it has a mild case of lifter tick, some rod knock and piston slap so it needs a major overhaul instead of just rebuilding it i am going to make it bigger and better via a 4.7 long rod stroker since i will be reworking the suspension next month now is the time for the build
so here is the plan
Jeep 4.2L 3.895" stroke crank
Jeep 4.0L 6.125" rods
IC944-060 pistons
9.36:1 CR according to the calculator
CompCams #68-231-4 206/214 degree camshaft
a stock 7021 HO cylinder head that is gasket matched
Mill block deck 0.020"
0.050" quench height
Ford 24lb/hr injectors with adjustable FPR
99 4.0 intake
stock exhaust manifold with a 2.5" exhaust all the way back
and bore the taper out of the throttle body and gasket match the intake
here is what it is going in
right now it has d44's f&r but is getting a ford 9" rear spooled with 5.13's and the welded front and matching gears
so is there any thing i need to do or not do also what should i do about the computer
Re: dieing 4.0 problem
Since your Jeep is a '92 it'll have the OBD1 engine controller in which case, you don't need to do anything to it. Just get the correct size injectors (Ford 24lb'ers) and fine tune the fueling either with an adjustable FPR or a MAP adjuster so that you'll have a WOT air/fuel ratio near 13:1.
gearhead1985
Vehicle Model: yj
Cheromaniac wrote:Since your Jeep is a '92 it'll have the OBD1 engine controller in which case, you don't need to do anything to it. Just get the correct size injectors (Ford 24lb'ers) and fine tune the fueling either with an adjustable FPR or a MAP adjuster so that you'll have a WOT air/fuel ratio near 13:1.
ok what is the best way to monitor the afr's
a wide band o2 and a gage
gearhead1985 wrote:ok what is the best way to monitor the afr's
a wide band o2 and a gauge
Exactly.
Users browsing this forum: Semrush [Bot] and 5 guests
