too much for machine work?
ftpiercecracker1
The 88 block i am going to use for the build needs to have the usual machining.
A local shop that i am trying out says it is going to run me about $625 for the block work and $325 for the crank work.
here is how they break it down.
BLOCK:
cleaning, new freeze plugs and cam bearings-$130 (shop cleaning is mandatory)
Bore & hone- $140
head & block decking-$140
miscellaneous -$68
Head:
basic valve job & adjustment-$148
Crank & rods:
+ crank turned and polished
+ pistons removed and replaced
+ rods turned and polished
= $325
NO balancing included
tell me what you think, i was really looking forward to this build, but the whole $1000 machine work bill has left a bad taste in my mouth.
BLOCK:
Bore & hone- $140
miscellaneous -$68
Head:
Crank & rods:
= $325
604rail_king
- Vehicle Year: 1995
- Vehicle Model: XJ
Re: too much for machine work?
if you feel its a bit much, get a 2nd quote.
machining rates can vary on a number of things (ie: where you live, how much competition there is, ect ect)
Antifreeze2
- Stroker Displacement: 280 ci
I'm there with ya. I've been asking my machinist for a quote since I dropped of the block and bulk of parts. 225 for the head related stuff, 2-300 for balancing crank and rods/pistons (sent to another shop), 250 for block work, and the bill is still not finalized. I've paid down $725 and I've had a hesitation with this guy since the beginning. I think they take advantage of the fact that they are the only reputable shop in the 75 mile area.
ftpiercecracker1
. . . and a 3rd and a 4th And a 5th.604rail_king wrote:if you feel its a bit much, get a 2nd quote.
there are lots of machine shops around my area, i just was lazy and took my stuff to the first one i saw.
Sounds expensive to me?, I can't find my receipt for my crank grind and crank/flywheel/clutch balance?, but the price to bore the block was $95
I want to say I'm only into the machine shop somewhere $250-300?, and that includes all three sets of bearings too.
doublins
- Stroker Displacement: 5.2L V8 (was 4.7L)
On my last build, I brought the head and shortblock to them separately, without the covers on, but with the rotating assembly and valvetrain still installed-
They stripped down and cleaned both, magnafluxed, bored/honed, line-honed the cam passageway, installed all new bearings & cam bearings, balanced and straightened crank, gapless rings, recon´d the rods, rebuilt my melling oil pump, replaced and welded the pickup tube- On the head, they opened up the valve seats for oversized valves, cut and installed hardened exhaust seats, deshrouded the CC around the valves, did moderate bowl work, decked block, then did complete assembly of everything- My labor cost was around $1200-
Oh they also tossed in boring out my throttle body and welding a wideband bung onto my header just to be nice.
What bearings did they use for the cam tunnel line hone? I haven't found any over sized OD bearings for the 4.0L.
Look for another machine shop. A $950 bill sounds steep to me for the work they're recommending.ftpiercecracker1 wrote:tell me what you think, i was really looking forward to this build, but the whole $1000 machine work bill has left a bad taste in my mouth.
Retlaw01XJ
- Vehicle Year: 2001
I've dealt with 2 shops in my area (eastern Pa). This shop did very nice work, but it was a bit higher than the other shop.ftpiercecracker1 wrote: BLOCK:
Bore & hone- $140
miscellaneous -$68
Head:
Crank & rods:
= $325
Degrease block (mandatory) $70
Bore and Hone $216
R&R Cam bearings $60
Cut deck 0.020" $128
Block total = $474
Valve job $160
Set stem heights? $40 I had to ask about this one...I didn't expect this charge. Spring height adjusted with shims, Valve tips are set to correct height.
Sono (crack check) $20
Resurface $70
Head total = $290
Rods:
Install ARP bolts and recondition rods $110
R&R pistons $80 (I thought this was too high)
Grind rod small for clearance to fit KB944 pistons $60 (caught me off guard.... I would've done this myself)
Rod total = $250
Machine shop total = $1014.
Higher than I expected, but that's what it costs around here....
Walt K
Eastern Pa
Eastern Pa
ftpiercecracker1
doublins wrote:On my last build, I brought the head and shortblock to them separately, without the covers on, but with the rotating assembly and valvetrain still installed-
You both are some lucky "bass turds",IH 392 wrote:Sounds expensive to me?, I can't find my receipt for my crank grind and crank/flywheel/clutch balance?, but the price to bore the block was $95
for everything i mentioned in my original post i figure something like $750 as a "resonable" price, IMO, but who am i to say.
ftpiercecracker1
I now have removed all of my parts from the machine shop in question, thank God I didnt owe them anything. After talking to some good people at my local NAPA, i learned that they are the highest priced shop in town, AND that they are known for poor quality work.
ftpiercecracker1 wrote:there are lots of machine shops around my area, i just was lazy and took my stuff to the first one i saw.604rail_king wrote:if you feel its a bit much, get a 2nd quote. Like i said. . .
lesson learned.
haroldpo6
- Vehicle Model: yj
Here they charged me
Dip block=$55
Dip head=$25
Bore block+80
Install cam bushings=$30
Install freeze plugs+$25
Dip block=$55
Dip head=$25
Bore block+80
ftpiercecracker1
Update. New shop, Reed Grant performance. Extremely helpful and welcoming, answered every question with humility and clarity. The man is an engine genius. 50+ years experience
price. . .
original (mike's speed shop)- near $1000
new (Reed Grant)- $550 and thats no expence spared
also has his own custom built dino, personally tunes each engine he builds.
price. . .
Now that's more like it!ftpiercecracker1 wrote:new (Reed Grant)- $550 and thats no expence spared![]()
ftpiercecracker1
you can say that again.
