Install wires for a AEM wideband
montelibre
Post by montelibre »
I bought two AEM wideband O2 sensors (part number 30-5130, one for the cylinders 1-2-3 and other for the 4-5-6) and I will to try install, but I don't understand where to connect the white and brown wires.
I need hep with question.
Re: Install wires for a AEM wideband
The wires are for external logging capabilities. For example, if you had an AEM FIC the the White wire would to the the FIC and the brown would be grounded. I don't fuilly understand the season for two wires though.
From the manual if you don't already have it.
WHITE – The WHITE wire should be connected to the Lambda + input on the
EMS or the analog + input on a similar device.
BROWN – The BROWN wire should be connected to the Lambda – input or the
analog – input. If the EMS or similar device does not have a – input, the BROWN wire
should be connected to a sensor ground. If no sensor ground is available, the BROWN
wire should be connected to a power ground. Note: The BROWN wire must be
connected in order to get correct readings from the analog output.
