cap separation
herbiehind
Vehicle Year: 1999
cap separation
Post by herbiehind »
if i place a pipe 2" round , in a vise , and place rod on pipe and hit bolt threads with brass hammer, will this separate the caps without damaging the roundness of the big end? these caps are tight!!! i got the rods out with similar method ,but these have been all worked and balanced now . machine shop is quite a ways away . should i bite the bullet on a separator? :doh:
herbiehind
Vehicle Year: 1999
Re: cap separation
nobody?
Re: cap separation
I usually just run the nuts to the end of the bolt to protect the threads then tap the nut to start it. If you don't have to hammer too much your method should be ok.
Re: cap separation
I usually just tap the ends of the bolts to get them to separate, a little finesse goes a long way!
herbiehind
Vehicle Year: 1999
Re: cap separation
yeah that's how i got them off the crank . came off easy. but now they tight!! gonna try the pipe and brass hammer . thanks guys
gonridnu
Vehicle Year: 1989
Vehicle Model: XJ 2 door
Re: cap separation
Post by gonridnu »
You can put the cap end in a vice and wiggle the cap off. It takes a small amount of work. Shops use aluminum jaws to protect the sides of the cap but you can usually get away with a rag. Most shops that do production rods don't use a one and I can't imagine buying a cap separator for one engine, but then again I can't imagine beating on the machined inside of a rod either, with or with out brass.
