Turn signals work properly all 4 corners, but the 4-way or emergency flasher does not activate the front right set of lamps, the rest are functional. Have no idea where to start tracking this on down - any suggestions?
99 XJ 4dr 4.0L
4-way Flasher issue
brotherwes
- Vehicle Year: 1999
- Vehicle Model: CherokeeXJ
- vashxj
- Vehicle Model: cherokee
Re: 4-way Flasher issue
this might be a little late did you fix it yet?
Carter417
when you turn your flashers on the front & back should flash, if they don't you need to replace the flasher for the 4 ways, the reason your turn signals will work is they have there on flasher. try to replace it its the only a wise decision.
