head replacement
head replacement
I am replacing the head in the next day or two. Is it best/easier to unbolt the manifolds and remove just the head or should i just unbolt the exhaust pipe and pull the head with the manifolds still attached. I have a hoist or manpower available to do it either way..just not sure which way to do it
- Vehicle Model: cherokee
Re: head replacement
I dropped the manifolds then pulled the head. If you have a cherokee the drivers side head bolt towards the firewall is a pain to get at to torque it to spec, ended up doing mine to match the feel on a properly torqued bolt with a long wrench .
- Muad'Dib
When i did mine, i removed the head with manifolds attached. I didnt want to fuss around with tight areas to get the manifolds off first. Be advised that this method is best for two people or someone with a hoist.. the manifolds can make the head awkward and heavy(er). Removal wasnt so bad for me as assembly. I actually tore up a HG because i tried doing it myself.
I havent tried the other method, but im sure that it takes less time doing it with the manifolds attached.
I used a hoist and pulled the head with the manifolds attached.
- Vehicle Year: 1999
- Vehicle Model: wrangler
i'm gonna try that next time. suckers heavy!! .
No shit. Even without the manifolds is still heavy to lift off yourself. I did that once and it was the last time.
