Anyone running the Mopar 30ab cam ?
kris
Learning to use the board
Post by kris »
Or mabye I should call it "Im cam-fused"...
Ive heard a bit of talk about this cam, but cant recall anyone actually running it. Can anyone give some impressions on it ?
Ive been pretty much set on the Comp 232-4 for my build, but over the weekend picked one of these up.
It advertises power between 1300-4800rpm, but what has me a bit confused is lobe separation angle of 108*, and 40* of overlap.
The LSA difference between the Comp 231-4 and the 232-4, and the 30ab is about 3* and 5* respectively, but the Comp appears to be ground 4* advanced which gives it an intake centerline of 107*.
Overlap for the two of them is at 32* for the 231-4 and 27* for the 232-4.
Comp says that the 231-4 is not for fuel injection but the 232-4 is ok with it.
For comparason, the Crane has a LSA of 112*, but an intake centerline of 107*, indicating being ground 5* advanced)
My concern is that most cams for the AMC I-6's have a LSA of 111-113*. Not knowing how these engines respond to narrower LSA's, it looks dificult to tell how a 108* LSA cam would run installed "straight up" (no advance).
Narrower LSA's are known for narrower powerbands with higher peak power, wider LSA's are known for broader powerbands, but less peak power (you dont get something for nothing).
The 30ab looks like it can be a great compromise between the Comp and Crane cams as long as the <1500rpm power doesnt suffer.
Any thoughts or experience ?
Flash, can you run the "DigiDyno" numbers on the 30ab to compare with the numbers in the "Cam FAQ" ?
Lift - 450"
Dur - 256*
IVO - 20
IVC - 56
EVO - 56
EVC -20
Overlap - 40*
LSA/ICL - 108*
:cheers:
kris.
RAPTORFAN85
Re: Anyone running the Mopar 30ab cam ?
Post by RAPTORFAN85 »
Not to rain on the parade but they don't make the mopar 30ab cam anymore, so unless you have a line on one It's going to be hard to find one.
"Strrrrroke me, stoke me...."
Billy Squire
Post by Flash »
As John has already mention in the FAQ section. The comp 231 works good ..........even tho comp don't recommend it for fuel injection :roll:
I have dyno sims of both the 231, and the 232, as well as the mopar 30ab. when i get home to night i will post then up.
If i remember right the 30ab made almost the same HP/torq as the 231 but did it with less lift.
the 232 that comp recamends............... well i wasn't impressed with it as well as the 231 :huh:
Mind you, the only testing of all of these cams, is with a computer program ONLY!
kris
Post by kris »
RAPTORFAN85 wrote:Not to rain on the parade but they don't make the mopar 30ab cam anymore, so unless you have a line on one It's going to be hard to find one.
Um, I believe I said that I did... :P
kris wrote:Ive been pretty much set on the Comp 232-4 for my build, but over the weekend picked one of these up.
Flash wrote:As John has already mention in the FAQ section. The comp 231 works good ..........even tho comp don't recommend it for fuel injection :roll:
I realize its only a simulation, but with all things being the same in the engine except the cam, it should show the difference between them. If you have a screenshot of the graphs on the 231/232/30ab, that would be great too...
Thanks,
k.
RAPTORFAN85
k.
Wow, I missed that sorry. Just skimmed over the article. You are lucky to find one.
Billy Squire
RAPTORFAN85
:cheers:
kris.
FWIW the stock HO (96-on) cam has a LSA of 107* and makes good of power down low.
Billy Squire
yuppiexj
Post by yuppiexj »
kris wrote: The 30ab looks like it can be a great compromise between the Comp and Crane cams as long as the <1500rpm power doesnt suffer.
If you are running an automatic; <1500 doesn't matter since the toque converter will take care that via torque multiplication.
If not, feel free to smack me in the face with a dead carp (although a stroker with a "top end only" cam will be hard pressed to have less power <1500 than a stock 4.0).
Post by Flash »
I though i had save the 232, but i didn't. Here is the other two
When i try to export it out it gets a little strange...........have no idea what some of these numbers are but added ( ) to help understand the data !
4.2 (crank)
0
0
1
AMC 4.0L ( bore)
4
1 3.875000 (Bore and stroke)
1 3.895000
6
1 5.873000
1 1.507831
0
jeep 4.0 HO 7120 head W standard valves(Head flow #s added)
17
1
1
1 1.9100001 1.500000 (int and exh valves)
1 9.440000 (Compression)
1 400.000000
1 1.500000
Single-Plane Std-Flow
1
Gasoline
1
1 0.000000
None
1
0
0 0.100000
0 0.100000
0 0.000000
0 1000.000000
0 10.000000
0 0.100000
0 0.100000
0 0.500000
0 0.000000
Small-Tube Headers With Mufflers
3
1
Comp 68-231-4.cam4.2
0
68-231-4
6
Hydraulic
1
Seat-To-Seat
1
1 0.000000
1 0.462000
1 0.485000
0
1 18.000000
1 52.000000
1 64.000000
1 14.000000
0.050-inch
2
1 -4.000000
1 30.000000
1 42.000000
1 -8.000000
1 3.000000
0
1
jeep 4.0 HO 7120 head.flw
4.2
0
6
1 1.910000
1 28.000000
1 0.100000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.600000
1 66.000000
1 128.000000
1 179.000000
1 206.000000
1 209.000000
1 209.000000
1 1.500000
1 28.000000
1 0.100000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.600000
1 55.000000
1 100.000000
1 120.000000
1 136.000000
1 141.000000
1 141.199997
1
1
0
2
0 0.100000
0 1.000000
0 0.000000
0 0.000000
0 0.000000
0 -0.500000
0 0.100000
0 0.100000
0 -100000.000000
0 -100000.000000
1 89.190002
0
21
--------HP--------Torq
1500 78.449814 274.678955
2000 112.951530 296.610718
2500 142.783203 299.958954
3000 172.722946 302.380310
3500 201.426422 302.254730
4000 217.781723 285.947388
4500 217.949432 254.371201
5000 200.498383 210.603500
5500 174.673904 166.797699
6000 138.926437 121.606941
6500 103.812973 83.880882
7000 64.414574 48.329334
7500 23.725611 16.614254
4.2
0
0
1
AMC 4.0L
4
1 3.875000
1 3.895000
6
1 5.873000
1 1.507831
0
17
1
1
1 1.910000
1 1.500000
1 9.440000
1 400.000000
1 1.500000
1
Gasoline
1
1 0.000000
None
1
0
0 0.100000
0 0.100000
0 0.000000
0 1000.000000
0 10.000000
0 0.100000
0 0.100000
0 0.500000
0 0.000000
3
0
4.2
0
MP 4529230
6
Hydraulic
1
Seat-To-Seat
1
1 0.000000
1 0.450000
1 0.450000
0
1 20.000000
1 56.000000
1 56.000000
1 20.000000
0.050-inch
2
0 0.000000
0 0.000000
0 0.000000
0 0.000000
1 3.000000
0
1
jeep 4.0 HO 7120 head 1.flw
4.2
0
6
1 1.910000
1 28.000000
1 0.100000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.600000
1 66.000000
1 128.000000
1 179.000000
1 206.000000
1 209.000000
1 209.000000
1 1.500000
1 28.000000
1 0.100000
1 0.200000
1 0.300000
1 0.400000
1 0.500000
1 0.600000
1 55.000000
1 100.000000
1 120.000000
1 136.000000
1 141.000000
1 141.199997
1
1
0
2
0 0.100000
0 1.000000
0 0.000000
0 0.000000
0 0.000000
0 -0.500000
0 0.100000
0 0.100000
0 -100000.000000
0 -100000.000000
1 89.190002
0
21
1500 76.380821 267.434723
2000 110.566292 290.347076
2500 141.877151 298.055511
3000 171.996719 301.108917
3500 203.336472 305.120911
4000 225.447678 296.012787
4500 231.853668 270.598999
5000 220.888809 232.021606
5500 197.692841 188.778687
6000 166.105301 145.397507
6500 134.106171 108.357788
7000 101.208687 75.935432
7500 61.659191 43.177876
8000 20.263168 13.302770
8500 0.000000 0.000000
9000 0.000000 0.000000
9500 0.000000 0.000000
10000 0.000000 0.000000
10500 0.000000 0.000000
11000 0.000000 0.000000
11500 0.000000 0.000000
When i get some time, i will try and get the 232 #s
P.S. Don't get to excited with the numbers, as they are High!!!!!!!!!!!!!!
Post by Flash »
:lol: Now that funny!!!!! :P
kris
Post by kris »
Thats a surprise, they're pretty much in a dead heat...
Peak HP for the 231 is [email protected]
Peak HP for the 30ab is 225@4k
Peak TQ for the 231 is [email protected]
Peak TQ for the 30ab is [email protected]
The 231-4 is slightly better under 2500rpm and the 30ab is slightly better over 3000rpm, but they are so close I doubt that anyone could feel the difference...
k.
Post by Flash »
kris wrote:Thats a surprise, they're pretty much in a dead heat...
k.
Yeah, I'm sure that why i didn't save the 232 cam.
I would recommend the 30ab over the 231, if A, You could still buy it. and B, because it has less lift for the same power........O and C, because it has a wider or standard lobe...............but sence they are not avalible...................231 is my pic for a good torq cam.
Hey Flash, have you ran the numbers on the crane 905 cam? I'm not buying one, just curios what it looks like on the computer dyno.
I have a 30AB cam that I am going to have profiled to see what the duration and valve timing events are at .050. The advertised numbers mean nothing to me. I was hoping to get it done this week, but it may be next week. I'll post the info if anyone is interested.
Post by Flash »
dwg86 wrote:Hey Flash, have you ran the numbers on the crane 905 cam? I'm not buying one, just curios what it looks like on the computer dyno.
I don't have the 905 have the early version 901that i have been told is the same spec :huh:
If you could dig up the cam spec's I'll run it and post it up.
Advertised duration is more important to me then @ .050 as the program runs better with it.
I can run it either way.
Flash.
Flash.
Yes same specs.
