Hello,
this is a fantastic forum, got so much info from it so far.
The reuse/ where to by list I saw on one of the other posts is fantastic.
I'm looking at building a "low buck" stroker, it is a '96 zj engine that will be going into a auto XJ.
I have the 4 weight crank with the long nose.
I'm looking at using a comp cams 68-231-4 or 68-232-4 not quite decided on that yet.
all the detail for the comp cams seems to be for the older 4.2 engine, I know alot is interchangeable between the engines but can someone please verify that the recommended comp cams springs #926 are good for use the a 4.0 stroker build?. or are some other springs better regarded?
Also apparently comp cams require 4.2 timing kit/ setup ( i can only assume that it is different from a 4.0 set up- I don't know).
my donor engine is missing the cam sprocket, timing chain, washer, bolt and any springs or pins that are supposed to be with it.
what will I require to get the comp cams cam installed, other than a new timing set (and bearings)?
First stroker, a little bit of clarification re cams/spring.
- I think I'll order a "tab"
- Vehicle Year: 1995
- Vehicle Model: XJ
Obd1 scanner.
'95 sport,4.6 stroker, 4.5" lift, 32"s, 4:10's, 8.25&SYE, taurus fan
Sydney Australia
Sydney Australia
Re: First stroker, a little bit of clarification re cams/spr
The CompCams 926 springs are too stiff IMO. Use the Mopar Performance 5249464 springs instead.rainman wrote:all the detail for the comp cams seems to be for the older 4.2 engine, I know alot is interchangeable between the engines but can someone please verify that the recommended comp cams springs #926 are good for use the a 4.0 stroker build?. or are some other springs better regarded?
You can get the Cloyes dual roller timing set from Summit Racing, and the cam bolt/spring/pin plus the washer from Hesco.
- Vehicle Year: 1999
You can also get the cam bolt, spring and pin from Morris 4x4 for half the cost of Hesco;
http://www.jeep4x4center.com/camshaft-pin-83502890.html
*I have no ties to Morris. First time I ever dealt with them was a week ago for that exact part. Shipping was quick and I think they only charged 2 bucks for shipping.
- superj
- Stroker Displacement: 4.5
- Vehicle Year: 1987
- Vehicle Model: wrangler
Morris 4x4 is great!! I have bought a number of things from them with no trouble at all and talking to their phone person is good too.
Plus, they are a Christian company too, if you care
We broke something, I think it was traction.
- Vehicle Model: XJ
As far as I can tell the comp cams springs & retainers are $100
and for the mopar performance springs and retainers you are looking at $260. that is a serious difference.
this is a crawler/ daily driver, not a competition anything. Does the stiffness of the comp cams springs rob the engine of horse power?
Obd1 scanner.
Sydney Australia
Sydney Australia
- BANNED
The stiffness destroys your cam lobes and lifters.
99 XJ M62 S/C
99 XJ M62 S/C
- Vehicle Year: 2001
The springs Comp sells for the 6 cylinder Jeep are for the old 4.2 engines. They are entirely wrong for a later 4.0!rainman wrote:As far as I can tell the comp cams springs & retainers are $100
The old 4.2 has a 1.8" installed height, and the 4.0 springs need a 1.64" installed height..... With a coil bind of 1.140", they would work to 0.440" of lift, but the spring pressure would be MUCH too high.
I find it sad that a major company like Comp even has these springs listed for a 4.0. An unwary customer could destroy his engine by using those 'recommended' springs!
I searched thru countless spring charts looking for an affordable drop-in replacement spring and eventually just chose stock springs and picked a cam that would work with them.
Walt K
Eastern Pa
Eastern Pa
- Vehicle Model: XJ
thank you very much for that.
I could not for the life of me figure out why guys, who in other ways appeared to be price sensitive (as am I generally) , kept opting for the mopar springs.
Obd1 scanner.
Sydney Australia
Sydney Australia
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Semrush [Bot] and 2 guests
