Electric fan controller?
EVIL95XJ
Vehicle Year: 1995
Post by EVIL95XJ »
stroker is done, waiting on my brown dog motor mounts and decided to do away entirely with the stock fans, i ordered three 9" 1500cfm fans
what is the best way to control these, first time setting electric fans up and need some good advice, id like to have 1 fan to come on at a lower temp and the other two at about 210?
thanks for the help
Paul
Ford 24# injectors - PM me
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Re: Electric fan controller?
Post by jeepman »
I Use Derale Adjustable Thermo Switches but they are designed for no more then 2 fans but with your plan of different temps you would need 2 controllers anyways...
EVIL95XJ
Vehicle Year: 1995
Post by EVIL95XJ »
The fans I ordered are 8 amps each. U think I could use the stock wiring to run 2 at the stock cut on temp and run a controller for the other fan for the lower temp?
tequila mike
Learning to use the board
Stroker Displacement: 4.6?
Vehicle Year: 1991
Vehicle Make: heep
Post by tequila mike »
You could allways run a correctly rated relay wired to come on with stock wiring.
Easy enough to do.
Dont know what the stock fan is rated at.
EVIL95XJ
Vehicle Year: 1995
Post by EVIL95XJ »
tequila mike wrote:You could allways run a correctly rated relay wired to come on with stock wiring.
Easy enough to do.
damn, never thought of that, perfect solution
thanks
