Help! false CPS reading
962dr4x4
- Vehicle Model: xj
I am building my first jeep its 96 4.0 xj and i just installed a 4.7 stroker create engine (I bought after market 24lb injectors). i just got it on the road and i am having problems. when its warmed up it sputters and cuts off it will start back up and drive but, longer i drive it the worse it gets and wont work right in tell it cools off. i get a timing issue/bad CPS reading. so i switched it out and its still doing it! anybody hAVE any ideas?
- superj
- Stroker Displacement: 4.5
- Vehicle Year: 1987
- Vehicle Model: wrangler
Re: Help! false CPS reading
double post: i think you are in the wrong section. maybe try down in one of hte stroker sections
We broke something, I think it was traction.
A bad cam position sensor will cause the same symptoms.
Users browsing this forum: Majestic-12 [Bot] and 1 guest
