Valve cover?
haroldpo6
Vehicle Year: 1995
Vehicle Model: yj
Valve cover?
Post by haroldpo6 »
Will a 1996 4.0 valve cover fit on a 1995 4.0?
cruiser54
Re: Valve cover?
Post by cruiser54 »
Yes, it will.
www.cruiser54.com
haroldpo6
Vehicle Year: 1995
Vehicle Model: yj
Re: Valve cover?
Post by haroldpo6 »
I noticed when looking at valve cover gaskets they list 96 and up, not for a 95?
haroldpo6
Vehicle Year: 1995
Vehicle Model: yj
Re: Valve cover?
Post by haroldpo6 »
Also the head for the 95 is 7120
The head for the 96 is 0630
but will the cover interchange?
anybody
Re: Valve cover?
Head doesn't matter as far as valve cover fit is concerned. The later steel valve cover will fit on earlier heads. The only thing that changes are the PCV elbows and grommets.
haroldpo6
Vehicle Year: 1995
Vehicle Model: yj
Re: Valve cover?
Post by haroldpo6 »
SilverXJ wrote:Head doesn't matter as far as valve cover fit is concerned. The later steel valve cover will fit on earlier heads. The only thing that changes are the PCV elbows and grommets.
Thanks
haroldpo6
Vehicle Year: 1995
Vehicle Model: yj
Re: Valve cover?
Post by haroldpo6 »
Just finished installing, fits like a glove.
woodjeep
Re: Valve cover?
Post by woodjeep »
The stamped steel 96 and up will fit all years because the bottom is flat...the 95 and down cast alluminum will not due to the ridge on the bottom. I ground down my ridge so the bottom was flat so my 92 cover fit my 96 head.
Re: Valve cover?
Yeah... i used a VC from a 2000 on my 90 RENIX. Just had to change out my CCV stuff (which is a good idea anyway).
