Which CAMSHAFT did you use and why....
Black00Sahara
- I think I'll order a "tab"
- Vehicle Make: Wrangler
- Vehicle Model: Sahara
I am in the process of switching out my cam and would like a list of the camshaft brand and model #'s you used, the specs and why you chose this camshaft.
Re: Which CAMSHAFT did you use and why....
I used a custom ground Engle cam. I used Engle because of the high lift ground they have that can be used with a .904 dia lifter. I could choose the lobe separation, intake and exhaust lift and duration, and whatever advance I wanted ground into the cam. I enjoy working with smaller companies. The customer service always seams better. And it wasn't a comp cam. There have been to many problems with comp cams for me to feel comfortable to use.
x2 on the smaller companies. After going through a Comp cam 68-231-4, some Crane, and a Hesco RVOB I went with a custom JCR cam. It is based on the 99+ cam core with wide lobes and the retaining plate. Seat duration is 260*/264*, .050" duration is 204*/208*, lift is .472"/.478". Out of Lunati, Comp, Crane and Isky, JCR was the only one interested in looking for the correct core.
- IH 392
Melling MC1376, it's a stock replacement cam for the '97-'99, my eyes tell me it IS! a stock cam with the wide lobes, my dyno simulations showed it to be better than either of the currently available Mopar Performance cams, and every one else seems to be having trouble with just about every available aftermarket cam??
- Muad'Dib
My Mopar cam has been great for me.. 229AC. Went with it because it has the wide lobes and its directly from mopar. Similar specs to the popular Comp 68.231.4
superstingray77
- Vehicle Year: 1999
- Vehicle Model: WJ
Stroker Version 1 had the Comp computer friendly grind it it that wasnt bearing friendly when it failed in 2000 miles!
Combination of seat pressures too high (thanks Titan you rule) and Comp cams core not passing the hardness test.
Stroker Version 2 has a custom ground Lunati Solid lifter flat tappet with 230/236 duration at .050 and .500/.525 lift.
So far 300 miles broken in properly (as was the previous one) for 25 minutes at 2200-2500 on Joe Gibbs Driven break in oil. What a difference, i can tell you for certain that the stroker engines LOVE the longer duration to fill the cylinder, and longer / higher lift on the exhaust side even with my CNC ported head makes a big difference.
604rail_king
- Vehicle Year: 1995
- Vehicle Model: XJ
Comp 201 as it can be run with the stock valve springs. yet to be run though.
Black00Sahara
Thanks for the responses. I shipped it off to a small shop. Custom Cams in MS. They were recommended by a friend and when I spoke with them, they were really helpful and actually listened to my problem. He's going to spin it in the cam doctor and get a reading and call me with options.
I am trying to stay with the stock spring setup. I need some new lifters, and read the thread on here that said the stock mopar lifters are the best. Even though they are way more expensive than the aftermarkets. Any thoughts on the lifters?
I haven't read that thread and don't agree with that. They are over priced and nothing special. I recommend a set of Hylift Johnson lifters. PN 2011. They are the correct size, good machining quality and have the disc valve instead of the ball. Out of the ones I have seen they look the best. They also come recommended from people that know more than I do. You can order directly from them. See here for a brief comparison, they are the same ones as the Crower camsavers minus the groove: http://www.jeepstrokers.com/forum/viewt ... f=5&t=1262Black00Sahara wrote: I need some new lifters, and read the thread on here that said the stock mopar lifters are the best. Even though they are way more expensive than the aftermarkets. Any thoughts on the lifters?
Black00Sahara
SilverXJ wrote:I haven't read that thread and don't agree with that. They are over priced and nothing special. I recommend a set of Hylift Johnson lifters. PN 2011. They are the correct size, good machining quality and have the disc valve instead of the ball. Out of the ones I have seen they look the best. They also come recommended from people that know more than I do. You can order directly from them. See here for a brief comparison, they are the same ones as the Crower camsavers minus the groove: http://www.jeepstrokers.com/forum/viewt ... f=5&t=1262Black00Sahara wrote: I need some new lifters, and read the thread on here that said the stock mopar lifters are the best. Even though they are way more expensive than the aftermarkets. Any thoughts on the lifters?
Ahhh, ok thank you. I was thinking you had recomended a lifter before but I forgot the name.... and forgot where that thread was.
Black00Sahara
I guess I should have also specified that I am looking to see what will run with the following set up.
its a 2000 with the OBD II computer.
and I am trying to run it with the stock head, springs etc...
Black00Sahara
I think i found my answer to a bit of my question (max lift height) with this thread
http://www.jeepstrokers.com/forum/viewt ... 17&p=29484
Anyone see anything wrong with the calculations ?
I originally went with the Crane 753905 cam (same as 753901) 'cause it had the power band that I was looking for. It performed great and I loved it. Too bad the Crane lifters turned out to be shite and after 34k miles, one lifter collapsed and another stopped rotating and took out a cam lobe. I went back to the stock cam after that and I haven't looked back since. My stroker's closing in on the 70k mile mark now.
Black00Sahara
What are the specks on your build?Cheromaniac wrote:I originally went with the Crane 753905 cam (same as 753901) 'cause it had the power band that I was looking for. It performed great and I loved it. Too bad the Crane lifters turned out to be shite and after 34k miles, one lifter collapsed and another stopped rotating and took out a cam lobe. I went back to the stock cam after that and I haven't looked back since. My stroker's closing in on the 70k mile mark now.
I don't understand how some people are using the stock camshaft? I thought these engines had to much compression to do that?
My compression ratio is in the 10.2/1 range.... I tried the stock cam and that is why I am changing it. The stock cam doesn't have enough duration to bleed off that compression so it will run on pump fuel.
Mine's an original poor man's 4.6L stroker recipe with a 9.25:1 CR.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Cheromaniac and 2 guests
