BIG PROBLEM, or not?
ftpiercecracker1
Post by ftpiercecracker1 »
Ok fellas just got my Bored TB from Leigh Performance Machine.
OOOoooo Preettttttyyy :P
BUT, heres the sticker, I have the old RENIX system and my old TB has two sensors like so. . .
:huh: What can i do? :huh:
and NO i will NOT be swapping everything over to HO, this has been enough of a headache as it is.
I have all the "upgraded" bolts on people have recommended from the "HP/TQ Gains" thread, and everything has checked out except this.
thanks
Re: BIG PROBLEM, or not?
ftpiercecracker1 wrote:BUT, heres the sticker, I have the old RENIX system and my old TB has two sensors like so. . .
The IAC valve (blue) should be a direct fit so undo the two Torx screws holding the IAC valve inside the Renix TB, pull it out, and transfer it to the HO TB.
The other sensor (red) is the TPS. After you remove it from the Renix TB, you'll need to lightly modify the TPS to make it fit properly on the HO TB.
ftpiercecracker1
thanks bud, in my reasearch I have found several writeups on overcoming this exact problem, i dont mind i just wish i knew before hand.
another thing i dont excatly understand is what does a TB for an auto have that mine doesnt?
thanks again
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
just the other knob for the TV linkage for the kickdown. but i thought all the tb's had that and were prettty much all the same? unless im thinking about the cruise linkage part or something
ftpiercecracker1
amcinstaller wrote:just the other knob for the TV linkage for the kickdown. but i thought all the tb's had that and were prettty much all the same? unless im thinking about the cruise linkage part or something
Eh? :|
cruiser54
Post by cruiser54 »
Why not send it back and get the Renix throttle body? Am I missing something here?
The linkage on the auto TB has a connector for the auto trans TV cable bTW.
www.cruiser54.com
ftpiercecracker1
Sorry for the lack on detail, on this stroker i will be adding all the bolt on upgrades, (- a super :cry: )
7120 head
99+ intake
Bored HO throttle body, fuel rail, bracket
97 power steering pump, no fabrication needed
The IAC sensor is a direct bolt on and i have read and saved a couple different DIY writeups too. It doesnt seem to hard actualy, just gonna take some kagigering.
I was wondering, why cant i just cut and splice in the HO connector in place of the Renix??? THIS seems like a good idea. :rockout:
You definitely need the Renix TPS because the HO TPS has different output voltages and it'll confuse your Renix computer.
ftpiercecracker1
thanks bud, :cheers: glad i asked before i did anything. I guess its back to manufacturing an adapter.
ftpiercecracker1
Ok, i have been to my favorite specialty hardware store and was pretty much :lol: at, sooo does anybody have a link to a decent writeup on this? I have spent hours on google with a bunch of threads, but few answers. I have a few ideas i would like to try, i just have to carve out the time to sit down and try them.
and are you 100% sure I cant just chop and swap the connectors, cause it would make my life soo much easier.
ftpiercecracker1
thanks :D
I already have one of those links saved to my computer, the one about "Performance gains for your ..." as for the other one as i was reading this quote really got my attention "I mean to notch the little bolthead that holds the arm thingy on. Make sure you notch it at the right angle. You'll also have to cut the arm part off." I will have to try this, but i cant believe it could be as easy as notching the head of the bolt, but if it is WOW, i will definately do a clear and picture full writeup of the process, the hardest part will be getting the right angle.
and ya Hesco is out of their freakin mind, 145 bucks, for that! :o Their was a guy selling an adapter from them that he apparently never used for like 75 bucks, it was gone before he even hit the submit button. :lol:
ftpiercecracker1
I know this thread has a little age on it, but i have since found a way to make an adapter for $1.01 If anyone is interested, i will put a link up so that everybody can see, as promised, i did a nice little writeup with lots of pictures and even a video!
Users browsing this forum: Google [Bot] and 12 guests
