Does anybody have any FSM or schematics for a 91 cherokee? yesterday i cleaned up the harness i'm going to use, cut out all the unecessaries like headlights wipers etc etc. However i'm left with a few wires attached to the bulkhead connected that trace back to the ECM plug. So, does anybody have the wiring or at least the ECM pinout so i can figure if the wires are required?
Thanks!
1991 XJ FSM wiring diagram
Mgardiner1
Boilermaker
Re: 1991 XJ FSM wiring diagram
I know its been over a month since you posted this...but if you still need '91 wiring diagrams drop me a pm, i can help you out.
1992 MJ Eliminator
Stroker in progress: Lunati Cam, Diamond Pistons, 4.0L Rods, 4wt Crankshaft 3727 Casting, Clifford Ceramic Coated Header,
99+ Intake, 62mm Throttle Body, 24# Ford Injectors
Comanche91
- Vehicle Year: 1991
- Vehicle Make: JeeP
- Vehicle Model: Comanche
You can download most of the XJ FSMs (as well as a lot of other stuff) here:
http://www.greatlakesxj.com/tech.html
