I have read the FAQ question on cylinder heads, but it didnt contain the info i needed.
I did find this http://www.jeepstrokers.com/forum/viewt ... =15&t=2773 after doing a google search, but i just wanted to start a fresh thread to make sure his figures were acurate.
What is the CC volume of a stock 7120 head? Stock valves, never been decked, no head work, period.
7120 head volume?
ftpiercecracker1
604rail_king
- Vehicle Year: 1995
- Vehicle Model: XJ
Re: 7120 head volume?
i never cc'd my untouched 7120 head prior to rebuilding as i did not have the tools/syringe to measure things, but im sure you've found that most stock 4.0 heads are typically 57-58cc (+- .5). i polished my combustion chambers but i did installed the magnum ss I/E valves, and with machining only a few thou, it yielded 61-62cc.
i believe it was mentioned the magnum valves will ADD 2-3 cc as they are undercut. polishing out the orange peel pours in the cc will also add 1-2cc.
from the FAQ's
what are you trying to figure out above & beyond the info we already know about 4.0 heads ?
from the FAQ's
from all that info, it would for the most part confirm that my 7120 head started at 57-58cc roughly.For every .010 you shave, you lose 1.4cc's from the chambers.
Or for every .007 you shave off the head, you reduce the chamber volume by 1cc.
Last edited by 604rail_king on November 7th, 2012, 4:48 pm, edited 1 time in total.
ftpiercecracker1
My machinist just wants to know the volume of the head i will be using as he is not as familar with the 4.0 strokers as he is with everything else
calculating compression ratio in such, determining everything before the machine work
Which exhaust valve did you go with?604rail_king wrote:installed the magnum ss I/E valves,
604rail_king
- Vehicle Model: XJ
2.02/1.62 valves
head is fully assembled and just sitting on my work bench
http://www.ebay.com/itm/MOPAR-MAGNUM-2- ... 5aeb1c9767
Two 7120 heads that I've cc'd came out at 56.5cc and 57.0cc respectively.ftpiercecracker1 wrote:What is the CC volume of a stock 7120 head? Stock valves, never been decked, no head work, period.
racing89
- Vehicle Model: comanche
604rail_king wrote:i never cc'd my untouched 7120 head prior to rebuilding as i did not have the tools/syringe to measure things, but im sure you've found that most stock 4.0 heads are typically 57-58cc (+- .5). i polished my combustion chambers but i did installed the magnum ss I/E valves, and with machining only a few thou, it yielded 61-62cc.
50ish cc on mine with the same mopar valves and .110 of the head ( because of the combustion chamber shape, the "standard "formula is only good to about .060 removal ?)
from the FAQ'sfrom all that info, it would for the most part confirm that my 7120 head started at 57-58cc roughly.For every .010 you shave, you lose 1.4cc's from the chambers.
ftpiercecracker1
Cheromaniac wrote: Two 7120 heads that I've cc'd came out at 56.5cc and 57.0cc respectively.
Thanks cheromaniac, thats what i needed.
Our Stroker Calculator uses a default value of 58cc's.. which is consistent with what Cheromaniac stated.
Diesel_dog
- Stroker Displacement: 5.0
- Vehicle Model: xj
The stock cylinder head is cast iron and weighs 60lb. The valve head diameter is 1.91"
intake/1.50" exhaust. Casting numbers are as follows:
Year............Casting No
1987-90......2686
1991-95......7120
1996-99......0630
2000-01......0331
Cylinder head flow figures (cfm) at 28inH2O pressure drop are:
Non-HO head #2686 (Courtesy of Greg Friedman)
Valve lift (in)..... 0.2 ... 0.3 ... 0.4 ... 0.5 ... 0.6
Intake flow.... 122.0 168.0 186.0 189.0 192.0
Exhaust flow....88.0 114.0 130.0 134.0 138.0
Ported non-HO head #2686
Intake flow.... 124.0 183.0 197.0 207.0 216.0
Exhaust flow....87.0 113.0 138.0 153.0 159.0
HO head #7120 & #0630 (Courtesy of John Brown)
Valve lift (in)... 0.1 ... 0.2 ... 0.3 ... 0.4 ... 0.5 ... 0.6
Intake flow.... 66.0 128.0 179.0 206.0 209.0 209.0
Exhaust flow. 55.0 100.0 120.0 136.0 141.0 141.2
HO head #0331
Valve lift (in)..... 0.1 ... 0.2 ... 0.3 ... 0.4 ... 0.5 ... 0.6
Intake flow..... 59.4 122.6 171.1 201.1 214.3 218.4
Exhaust flow...47.1 93.4 123.3 140.9 147.0 149.7
Ported big valve 2.02/1.60 HO head
Intake flow.... 73.9 142.4 197.8 229.8 247.0
Exhaust flow. 65.3 114.0 135.9 146.3 157.1
The early '87-'90 non-HO heads have low intake ports that flow rather poorly. The later HO
this is what i have found
1987-90......2686
1991-95......7120
1996-99......0630
2000-01......0331
HO head #0331
