who has a 4.6 supercharged
- vashxj
- Vehicle Year: 1999
- Vehicle Model: cherokee
so has anyone in here run 8psi of boost on a 4.6 stroker with 9.6 cr. i was just building my 4.6 to run nitrous but i have come across a deal on the s/c unit i want. so im just thinking of building the whole thing
- BANNED
Re: who has a 4.6 supercharged
What supercharger? What's the plan?
99 XJ M62 S/C
99 XJ M62 S/C
I'm working on an MP90 for my 4.6L, but it won't be ready for another few months.
OP, Give me a buzz when you're ready....
- vashxj
it going to be a vortech v1 s-trim for a mustang but you have to tap the oil lines in the pan. i was thinking about forking a couple more bucks out for the self contained v3 but they are quieter, i like my friends mustang it really whines, also the v3 take its own special fluid. then im going to use a bigger mustang tb with 42lb injectors and the aem controller
42lb injectors may be a bit large
With a proper tune those injectors will be fine.SilverXJ wrote:42lb injectors may be a bit large
- BANNED
How much boost do you plan to have and how much additional power?
99 XJ M62 S/C
99 XJ M62 S/C
- vashxj
Im going to run 8psi and it should be around 350hp and 400lb at the flywheel i tried to underrate all my math but this should be a close estimate. Those injectors will be 45lb on my fuel rail. My friend runs 65lb but his engine was built for 15psi of boost he is at 9.25 cr. I know i will probly have to run premium all the time and 110 at the track.
- vashxj
And silver what cr is your engine and are you getting your intake machined for a direct bolt up for the s/c? Mines going where the a/c compressor normally is.
Why run a piggyback when you can tune through the stock PCM?
- vashxj
can you program for 8 pounds of boost?, i didnt think that was possible with a stock pcm, the map doesnt see positive pressure... i could be wrong that was just my understandingFlyinRyan wrote:Why run a piggyback when you can tune through the stock PCM?
You would replace the stock map with a 2 bar one.vashxj wrote:can you program for 8 pounds of boost?, i didnt think that was possible with a stock pcm, the map doesnt see positive pressure... i could be wrong that was just my understanding
Its 9.5:1 SCR and 8.0:1 DCR. I need to CC the combustion chambers again to verify. Yes, I will me machining the intake manifold at an angle, welding a plate on and then bolting the SC on. Sounds a lot simpler than it is.vashxj wrote:And silver what cr is your engine and are you getting your intake machined for a direct bolt up for the s/c? Mines going where the a/c compressor normally is.
My build:
http://www.jeepstrokers.com/forum/viewt ... f=8&t=3533
- vashxj
Well i realize i can replace the map but i didnt think the pcm would still be able to read right
It needs to be reprogrammed to understand the 2 bar map
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Semrush [Bot] and 1 guest
