HELP- Need 4.0 Crankshaft Nose Dimension
CobraMarty
Post by CobraMarty »
Can someone please help. I am having a harmonic damper built.
I need the Crankshaft Nose Dimension for a stock 4.0 crank. That is, the diameter of the front of the crank where the damper bolts onto.
Also the inside diameter of the harmonic balancer/damper where it bolts onto the crank.
Need the measurement to 4 places. example 1.xxxx
Thanks.
99 XJ M62 S/C
Re: HELP- Need 4.0 Crankshaft Nose Dimension
Why not go measure your own?
CobraMarty
SilverXJ wrote:Why not go measure your own?
All bolted on the engine.
99 XJ M62 S/C
Take the harmonic balancer off and measure away.
CobraMarty
I would but the Jeep is not home, I am at work, it is snowing outside. I want to do the removal and install only once.
99 XJ M62 S/C
Vehicle Make: Jeep XJ
CobraMarty wrote:I need the Crankshaft Nose Dimension for a stock 4.0 crank. That is, the diameter of the front of the crank where the damper bolts onto.
It's 1.1250" or 1-1/8".
CobraMarty
Thank you.
99 XJ M62 S/C
