Need some options on stroker
jeepsluvmud
Vehicle Year: 1989
Post by jeepsluvmud »
Hey guys. Im rebuilding my 89 4.0l. I got a extra block so i can work on it on my spare time. I just need the lower end set up. I got a new head,timing gears, oil pump, injectors... ect on the old block. So here is what im thinking of doing. I got a 4.2l crank, 4.2l rods, comp cams part #753901. I need some help on what pistons to put in it. I wanna go .30 over and run 89-91 octane gas. I really want something thats got a little more pep, i dont have the H.O motor so i want a little more hp. what do you guys think??
Re: Need some options on stroker
That's a Crane cam part no. that you quoted but it's still OK anyway. The most suitable piston for your combo would be the Speed Pro H825CP and it'll yield a CR of ~9.5:1.
jeepsluvmud
Vehicle Year: 1989
how long have you had your stroker in your jeep? I want to build one but i dont want to rebuild it every couple of yrs
8-1/2 years and 70k miles. Still goes like a raped ape.
jeepsluvmud
Vehicle Year: 1989
what was your recipe? I want some real life build with real life results. lol
It's the original "poor man's" recipe on my site and my real life dyno numbers were after I did an '01 XJ intake manifold swap. I had 54k miles on the engine at the time.
jeepsluvmud
Vehicle Year: 1989
did you bore the cylinders?
jeepsluvmud wrote:did you bore the cylinders?
Yes, +0.020". My stroker is "square" with a 3.895" bore and stroke.
Users browsing this forum: Amazon [Bot] and 3 guests
