My Jeep 4.0 spun a main bearing on it, so am in the process of pulling it, and going to rebuild.
Someone I know has a AMC 258, 81 block, that he dissasembled and was going to rebuild.. will sell me everything for 200. Has all the rebuild kit.
Question is, what can I re-use? Know I want the crank and rods. He has .60 over pistons. I know that the stock 258 pistons are too small, but the .60 over pistons should be close to the same as a .30 over 4.0 piston?
What about rest of the stuff? Assume his new main bearings, cam bearings, etc will all work. He bought a hopped up cam for it, but still not sure if it's better than my 4.0 stock one?
Very noob at this myself, but am fortunate to have the help of someone who is experienced at rebuilding engines help, but he's never done this particular project before either.
Thoughts?
Starting the Stroker project
98grand
- Vehicle Model: grand
Re: Starting the Stroker project
The only parts you'll be able to use from that 258 are the crank, rods, rod bearings, and cam bearings. The 258 main bearings won't fit in your '98 4.0L block.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
