Injector part number needed.
Stroker Ace
Post by Stroker Ace »
Last piece of the puzzle is to get injectors before I install the stroker. My jeep is a 1998 and the its a low buck California smog friendly ( :doh: ) build. I hear about FMS (can't find them instock), Venom, Accel, etc. What injector will work with my harness? Anyone have part numbers and a place that has them in stock? I don't do Ebay. THANKS!
JeepFamily
Vehicle Model: ZJ
Re: Injector part number needed.
Post by JeepFamily »
I would recommend a set from Fuel Injector Connection. These are flow balanced units. I've also found it very helpful to speak directly to them, found them easy to get a hold of and very knowledgable. They have a set specifically for your stroker and came highly recommended by my machinist. I have a set installed in my 4.7 stroker. Below is a link to their site.
http://fuelinjectorconnection.com/shop/ ... ductid=279
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
2000 WJ Limited (Totaled)
2002 WJ Limited 4.7HO (Sold)
2003 WJ Overland 4.7HO
2005 WK Limited (sold)
1997 ZJ Orvis 5.2 Up Country(48K miles)
1997 ZJ Laredo (parting out)
1998 ZJ Limited 5.9
Wrangler Want-ta-get-one
FlyinRyan
Post by FlyinRyan »
OP, what are you doing for tuning your stroker?
Flyin' Ryan Performance
JeepFamily
Vehicle Model: ZJ
We are using a PLX Devices OBD II WiFi connector and Droid smart phone running Dash Command. Is this what you mean? So far we haven't had to make any changes to the MAP or PCM to get the engine within specs.
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
1998 ZJ Limited 5.9
No, that isn't tunning, but monitoring.
grainofsalt
Stroker Displacement: 4.61
Post by grainofsalt »
I offered them $100 shipped and they took the offer: http://www.ebay.com/itm/310136653389?ss ... 1436.l2649
Great customer service, Now I just need summit to send me a good water pump so that I can get the motor in and running.
JeepFamily
Vehicle Model: ZJ
very good indeed!!!
JeepFamily (Rob)
1997 ZJ 4.7 Stroker
1998 ZJ Limited 5.9
I didnt realise that you needed EV1 Connector Style Injectors.. im selling some. Oh well ;)
Users browsing this forum: Ahrefs [Bot] and 9 guests
