Boosted strokers
Luke95
Boosted strokers
Post by Luke95 »
I am looking to do a stroker on my Renix 1988 cherokee block, it will be replacing the 200K+ motor in my newish 98
Id be going the cheap route with it and putting in a 4.2 crank with rods and 4.0 pistons
How deep of a dish piston do I need to get to a comp ratio of between 8:1 to 8.5-9:1?
Injectors
What size will work in a 98 fuel rail that is big enough to provide the fuel for the boosted 4.5?
I know 30# is the hot number on Pirate 4x4 but they are on stock engines.
I have the turbo and the renix manifold to mount the turbo to.
Tunning idears? I was going to follow the pirate recipe of a GM 2 bar map and flashing it :D
The turbos a 16G off a mitsubishi eclipse, I am looking for around 4-5 PSI of boost.
Any one able to help me a bit?
FlyinRyan
Re: Boosted strokers
Post by FlyinRyan »
I can tune the stock PCM for a 2 bar application .
Flyin' Ryan Performance
Luke95
Post by Luke95 »
What is the cost on that?
Luke95
Post by Luke95 »
yuppiexj
Post by yuppiexj »
FlyinRyan wrote:I can tune the stock PCM for a 2 bar application .
Will an ODB2 conversion be required? I haven't seen a RENIX flash.
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
I think it's actually going in a 98, not a renix
Luke95
Post by Luke95 »
amcinstaller wrote:I think it's actually going in a 98, not a renix
It is, It is a 88 block going into my 98 cherokee
FlyinRyan
Post by FlyinRyan »
Luke95 wrote:What is the cost on that?
465.00 , revisions and retunes are no additional cost. you pay one fee up front, and thats it.
Luke95
Post by Luke95 »
Now that would work for me boosted and just swap in so I dont have to tune with a mega squirt yes?
the_wrench116
Post by the_wrench116 »
what is your entire set up going to be are you going to use the renix head and a renix intake manifold?
FlyinRyan
Post by FlyinRyan »
Luke95 wrote:Now that would work for me boosted and just swap in so I dont have to tune with a mega squirt yes?
As long as your PCM number is supported, yes, we load tunes via the OBDII port , no MS needed.
Luke95
Post by Luke95 »
From a tuning stand point is their a difference between a turbo and a supercharger?
turbostroker
Vehicle Year: 1991
Post by turbostroker »
Luke95 wrote:From a tuning stand point is their a difference between a turbo and a supercharger?
It's a big difference on the boostcurve.
Supercharger has a pretty straight boostcurve from low too high rpm but turbochargers has a quick rising edge at higher rpm depending on the specifikations on the turbochargers.
It's because of that I put two small turbochargers at my Jeep then I got boost on lower rpm, If I instead have but one big tubochargers the boost had came on higher rpm and on a Jeep I don't want too have that.
There for it's a differens in mapping a supercharged then a turbochargd engine.
Jeep Wrangler -91 Twinturbo 4.6 Stroker
Bo Wernersson
CobraMarty
Post by CobraMarty »
Twin screw superchargers like the Sprintex have full boost at low rpm.
99 XJ M62 S/C
turbostroker
Vehicle Year: 1991
CobraMarty wrote:Twin screw superchargers like the Sprintex have full boost at low rpm.
Yes, Sprintex have a pretty straight curve from idle too high rpm but these superchargers don't give as much horse power if you will built a race Jeep but are perfect on a daily driving Jeep or terrain Jeep.
I see that you have a boost on winter at 7.5 psi and thats are not soo much.
I run at 18 psi on my 4.6 stroker engine with 2 turbochargers and have boost at 1200 rpm.
Bo Wernersson
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 1 guest
