Injector identificaton
- cruiser54
- Vehicle Model: Comanche
I got a used 4.6 stroker that needed freshening up. I've done that and I'm gonna install it into a Renix Jeep.
It came with a set of injectors that were used with the stroker in an HO application.
The injectors say Denso, Ford, BZ, 964, and 2881. And they're gray.
Anyone know the specs?
www.cruiser54.com
www.cruiser54.com
- cruiser54
Re: Injector identificaton
Anyone?
www.cruiser54.com
www.cruiser54.com
Post pics with both sides clear.
If there is a ford part number on it it is usually in a form like this F47E-A2D or 968F-AC... or like this on newer ones if there is room F0TE-9F593-D9B
- cruiser54
Only what I posted. Does the 964 mean something?
www.cruiser54.com
www.cruiser54.com
- cruiser54
I went to Denso's website and requested some help. I'll post up what I find.
www.cruiser54.com
www.cruiser54.com
- Vehicle Year: 1995
- Vehicle Model: Grand Che
If If you can send me a couple pics of the injectors I could probably help you out. I might even have the rebuild parts laying around if you need them.
- cruiser54
They're installed, and new or rebuilt, on my stroker sitting on the stand. Is that okay for a photo?
www.cruiser54.com
www.cruiser54.com
Should be. Just try to get as much of the injector body as you can.cruiser54 wrote:They're installed, and new or rebuilt, on my stroker sitting on the stand. Is that okay for a photo?
- cruiser54
Great idea on the photo. As the flash went off, I saw some smaller ID numbers. 968F-AC.
So, 968FAC injectors are 21s from what I gathered on my Google search.
Never woulda seen those numbers if I hadn't been asked to photograph them!! Thanks.
www.cruiser54.com
www.cruiser54.com
Around 21.1lb @ 3 bar (43.5PSI). So at 39 psi they would be 20 lb/hr
I'll have an extra set of Ford 24# blue injectors hopefully in a week or so if you want to upgrade.
- cruiser54
They came with my stroker, but you guys think they're too small?
www.cruiser54.com
www.cruiser54.com
The might be, but Mau'dib has had good luck running stock sized injectors on his Renix.
- cruiser54
I'll try them then. Thanks.
www.cruiser54.com
www.cruiser54.com
- Muad'Dib
Just be sure to monitor AFR and if possible your STFT.
