Injector part number needed.
Stroker Ace
Post by Stroker Ace »
I have a 98 TJ with a budget 4.6L going in. I know most say FMS-M9593-A302, but I cant find them anywhere. I've been told that M-9593-LU24A would work, but i'm not sure of the overall dimensions fitting the rail. Some others have been saying go to fuel injector connection, but they are like $850 for a set. Help!!! The engine is going in next week. Thanks. :deadhorse:
00XJ49
Re: Injector part number needed.
Post by 00XJ49 »
Don't buy brand new injectors - big waste of money.
If you search eBay for "M9593-A302" you'll get some hits.
If you do a search for something like "jeep stroker injectors", most of what pops up will probably work for you (I believe you've got the 39 psi rail). You want to aim for 24 lb/hr @ 43.5 psi (which works out to a little over 19 lb/hr @ 39 psi).
"Roads? Where we're going, we don't need roads..."
