What is the max valve lift I can go on a stock 4.0 bottom end without hitting the pistons?
Thanks guys! (forum is awesome btw too)
2000 Jeep 4.0 Max Valve Lift
trombly
- Stroker Displacement: 4.0
Retlaw01XJ
- Vehicle Year: 2001
Re: 2000 Jeep 4.0 Max Valve Lift
The 4.0/4.6 has ample valve-piston clearance. Shouldn't be an issue unless you get real crazy with mods.
Valve spring/retainer/valve height IS a concern with higher lifts.
A stock setup should work up to 0.460" valve lift. More lift will require some mods to the valvetrain or head machining.
Some stock measurements here:
http://www.jeepstrokers.com/forum/viewt ... =coil+bind
Walt K
Eastern Pa
Eastern Pa
trombly
So if I change the springs to .550 with a .460/.476 lift cam I should be alright?
Retlaw01XJ
0.476" lift should theoretically work with stock springs, but you would be exceeding the safety margin... it would not be recommended. Spring pressure may be too low as well.trombly wrote:So if I change the springs to .550 with a .460/.476 lift cam I should be alright?
I don't know what you mean by .550 springs?
Replacement performance springs usually require new retainers and locks. Might need a bit of head machineing too.
Walt K
Eastern Pa
Eastern Pa
