49 psi regulator
the grey ghost
- Stroker Displacement: 4.611
- Vehicle Model: comanche
49 psi regulator
I know I read somewhere that there might be a direct drop in replacement for the 91-95 fuel pressure regulator that flows 49psi but I can't find it now, anybody ever do more digging on that?
the grey ghost
Re: 49 psi regulator
Update someone on eBay is selling them,oblviously not going to tell the rest of us where it came from
the grey ghost
For anyone that cares its a 48 psi regulator from a 1995 dodge caravan 3.3l v6
cruiser54
- Vehicle Model: Comanche
www.strokedjeep.com has adjustable FPRs......
www.cruiser54.com
www.cruiser54.com
the grey ghost
Yeah but this one is 20$ plus shipping. Besides why do you want it adjustable?most of us run trim pots or tuners, a nice high fuel pressure and ev6 injectors, then trim it back with the tuner
the grey ghost
Besides this cost me around ten bucks
Zorm
- Vehicle Year: 1983
so Grey Ghost, what did that come out of? is that a little bit adjustable?
PseudoSport
- Stroker Displacement: 4.0L Turbo
- Vehicle Year: 1995
Found some fuel pressure regulators that should interchange with the stock one and increase pressure.
Standard Motor Products Part #'s
PR210 39 psi (stock)
PR211 50 psi
PR209 55 psi
PR321 58 psi
I'm currently running the 50 psi one from an Interepid in our team's turbo XJ. The others should work but I matched them up in a catalog and can't confirm they fit.
PR211
CHRYSLER CONCORDE (1993 - 1997)
CHRYSLER DYNASTY (1991 - 1993)
CHRYSLER IMPERIAL (1990 - 1993)
CHRYSLER INTREPID (1993 - 1997)
CHRYSLER LHS (1994 - 1997)
CHRYSLER NEW YORKER (1990 - 1996)
CHRYSLER TOWN & COUNTRY (1990 - 1995)
DODGE CARAVAN (1990 - 1995)
DODGE DYNASTY (1990 - 1993)
For the rest you can plug them in on rockauto fit find the applications. Hope this helps.
PR211 50 psi
PR209 55 psi
PR321 58 psi
PR211
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
the grey ghost
That was actually a stock regulator that I modified by cutting the backside off and jb welding a brass cap on, it worked but I blew the diaphram as it was a prototype made from a junkyard regulator
the grey ghost
Thanks for the info spuedosport
