timing
- I love this board
- Vehicle Model: cherokee
timing
can anybody post the timing maps their using? i know shit about timing and would love to get better then 10 mpg till i can afford to take it to a tuner and have it tuned right
- Stroker Displacement: 4.611
- Vehicle Model: comanche
Re: timing
What kind of timing are you running now?
- I love this board
Re: timing
Telling us your setup would help. Timing demands are heavily dependent on the configuration.
- I love this board
Re: timing
lunati 63501 installed straight up. bored .020, 99+ intake, 68mm throttlebody, 4.2 crank, aw4, np242, 35's with 4.10 gears
- Learning to use the board
Re: timing
So, I take it this is normally aspirated ? I see what looks like map going up to 400 (kPa ?) It's hard for me to read the numbers, but I would say, you want to adjust your timing so that you are running the minimum amount for maximum torque. If you are limited to street tuning, I would recommend driving around, datalog, and watch where you hover in the map, try bumping timing a few degrees at a time. The timing can be considerable more advanced at part throttle than at full throttle. How is you lambda ?
OBD1 and OBD2 Jeep tuning (Renix, SBECII, JTEC, JTEC+, NGC) , re-programming via handheld programmer or bench flash.
Live mapping available using ecu memory emulation and high speed SCI logging.
Expert DCX tuning for over 9 years.
- I love this board
Re: timing
yes naturally aspirated. afr's are all pretty good, well within spec. i really wanted to get a knock sensor before starting with timing adjustments but i can't afford to keep driving it at 10 mpg. so i'm assuming i increase the timing at cruising loads but leave the wot loads alone? how do i know when i've gone too far? or not far enough?
Re: timing
The timing does not look too unreasonable, have you verified that indicated timing matches measured?
- I love this board
Re: timing
no i haven't. guess i need to break out the timing light and check it
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
