AEM F/IC Oxygen Sensor Hook Up...
- Vehicle Year: 1987
- Vehicle Model: Comanche
If I will be tuning via AEM's UEGO wideband sensor does the AEM F/IC really need to tap into the stock narrowband oxygen sensor? The only reason I can see it needing to do this is for changing the signal in case the PCM freaks out over the AFR changing against what it thought should happen after the F/IC adjusts other parameters. The other, why does it tap with 1k OHM resistor instead of intercepting?
Re: AEM F/IC Oxygen Sensor Hook Up...
You don't have to tie into the factory narrow band. As for adjusting it really doesn't work. I tried it every which way on mine and it either doesn't do anything or makes it go very lean or very rich.
I have seen a few others around the internet that indicated the only way they got it to work was using a much higher value of resistor. I will just leave the wire capped off in the harness for now.SilverXJ wrote:You don't have to tie into the factory narrow band. As for adjusting it really doesn't work. I tried it every which way on mine and it either doesn't do anything or makes it go very lean or very rich.
Users browsing this forum: Amazon [Bot] and 3 guests
