Speed Pro CS-1069R Camshaft?
PseudoSport
Stroker Displacement: 4.0L Turbo
Vehicle Year: 1995
Post by PseudoSport »
Has anyone used the Speed Pro / Sealed Power CS-1069R Camshaft? It looks like its only a slight upgrade over stock but does it have the wider lobes like the OE cam?
http://fme-cat.com/overlays/part-detail ... brandId=SD
Intake Duration @ .050" Lifter Rise deg 208
Exhaust Duration @ .050" Lifter Rise deg 208
Valve Lift (Intake) .421
Valve Lift (Exhaust) .421
Valve Overlap deg (advertised) 56
Lobe Separation Angle deg 112
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
