AEM FIC6 users: what slave firmware version are you running?
Which Z firmware file?
Z104
1
100%
Z107
0
No votes
Z110
0
No votes
Total votes: 1
If you are using an AEM FIC6, what is the Z firmware file you are running? Any issues?
How to Verify Firmware:
1. Go into the F/IC software and click on File. Scroll down and click on "Get Slave Version."
2. Follow instructions until you get the "Form1" window.
3. Unplug the USB cable from the F/IC. Press and hold the Re-flashing button on the F/IC with a paperclip while plugging the USB cable back into the F/IC. Continue to hold the button for 5 seconds and click the continue
button in the software.
4. The “Form1” window will appear and display the firmware version.
Z files (Handle fueling and firmware):
- Z104.hex: Used on older vehicles where multiple injector pulses are not present
- Z107.hex: Updated version of Z104.hex, used for Scion TC
- Z110.hex: Used for newer vehicles that have multiple injector pulses. Faster response time than other hex files.
atias
Re: AEM FIC6 users: what slave firmware version are you runn
Post by atias »
i'm using the z104 that you gave me on obd1 ecu.
