Springs for Comp Cams 68-232-4 - Mopar Discontinued
djergensen
Vehicle Year: 1994
Post by djergensen »
Hey Yall,
Finishing my stroker build. I have the comp cams 68-232-4 and I originally purchased the comp cams recommended springs. Once we received them we realized a couple of major issues... Stiffness and how they fasten. The guy I am building with did not feel comfortable with them.
So, I ordered the mopar performance springs #5249464 with retainers #4452032, & locks #4529218. Here's the problem. Mopar isn't making them any more!! So, I can't get those springs and I don't want the comp cam ones. What is my next best option?
Please Help!!
jeepxj3
Vehicle Model: xj
Re: Springs for Comp Cams 68-232-4 - Mopar Discontinued
Post by jeepxj3 »
Couple choices you might look into- these would be very close to the MP springs-
Scorpion 1214 conical [email protected]" install height, [email protected]"(0.450"lift)
CompCams 26125 install at 1.70-1.72" install height, [email protected]" install height, [email protected]"(0.450"lift)
Any others?
djergensen wrote:So, I ordered the mopar performance springs #5249464 with retainers #4452032, & locks #4529218. Here's the problem. Mopar isn't making them any more!!!
:shock:
djergensen
Vehicle Year: 1994
bump... need some help here
broncocliff
Post by broncocliff »
I am in the same situation buddy. When I talked to Lunati cams they recommend Hughes Engines for the springs and retainers. I just called them this morning and they gave me the part numbers for the springs and retainers. They also fit into the stock cylinder head location without having to bore it out some. I will be ordering these with my cam.
Part#
1110 - springs $6.55 x 12 = 78.60
1278 - retainers $ 48.00 - they sell these online as a set of 16 for $64 but if you call them they will give you only 12
And the original valve stem locks will work with this setup.
I guess you will need to check your lift on the cam you are going to use to make sure that the springs will work for you.
I hope this helps. The guy I talked to was very helpful.
Has anyone had experience with Hughes?
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
Any specs on that Hughes valve spring?
broncocliff
Installed Height/Pressure: 1.660"--120#
Pressure @ .450" lift: 280#
Pressure @ .500" lift: 300#
Pressure @ .550" lift: 310#
Coil Bind: .620" lift
Outer Spring ID/OD: 1.033"/1.440"
Type of Spring:Single w/ damper
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
IDK but I think that those numbers are higher than the MP springs.
broncocliff
Not sure I can't find the specs for the mopar springs. I would like to see those specs.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
MP Springs
Install at 1.64" 90-113 [email protected]" [email protected]"(0.450"lift) safe to 0.525" lift 270 lbs/in
broncocliff
So do you think the Hughes springs have to much pressure then? Maybe they have a lighter spring or is that not that much difference?
broncocliff
What did you decide to go with?? I will be buying some soon. Do you think the hughes was will work?
broncocliff wrote:Installed Height/Pressure: 1.660"--120#
Fawk, that is way to much SP. Cut the numbers by damn near 50% and you`ll be happier.
