677cp piston dish?
Defcon92
Stroker Displacement: 4.2l
677cp piston dish?
Post by Defcon92 »
Factory specs I've seen listed as 13.4 off Dino's parts selection page.
14.0 cc dish posted by a user named John here.
And in the piston FAQ Dino listed his with a minor polish at 17.5cc dish :banghead:
Summit shows .116 recessed dished which isn't helping me much. What's the factory untouched dish of a 677 piston?
Re: 677cp piston dish?
Defcon92
Post by Defcon92 »
SilverXJ wrote:Check the last post in the FAQ http://www.jeepstrokers.com/forum/viewt ... ?f=34&t=67
I did but the infos conflicting. 1 spot posted at 14cc, another at 13.5, another at. 17.5cc :doh:
Using the plexiglass method I cc'd my stroker's 677P pistons (after smoothing rough casting) at 17.5cc and my original stock 4.0 pistons at 13.1cc.
Silvolite quoted 11.5cc for their 2229 pistons while KB quoted 21.0cc & 10.8cc for their IC944 & IC945 pistons respectively.
I've tried for years to find reliable numbers for other pistons with mixed success.
I think the quoted number of 15.1cc for the Sealed Power (Sterling) hypereutectic H802CP/H825CP is correct and since the 677APs share the same dish dimensions, it's likely that those will also be ~15.1cc.
darkcorp
Vehicle Year: 1999
Vehicle Make: JEEP
Vehicle Model: GCh 4.0
Post by darkcorp »
Dear Cheromaniac!
Do you have pics of your 677P pistons after smoothing rough casting? Very interesting.
Unfortunately I didn't take any pics after I'd sanded the piston dishes down to a smooth finish. Here's a pic of the 677P pistons in their raw form:
I was somewhat surprised that mine cc'd as high as 17.5cc as the as-cast versions are probably more like 15.1cc. I even checked a second piston and got the same result so it wasn't a fluke either.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 6 guests
