........does anyone know where to find one? Or even a good low milage one?cam button and spring
sly-jeeper
- Vehicle Year: 1994
- Vehicle Model: cherokee
Trying to find a new cam button and spring is like
........does anyone know where to find one? Or even a good low milage one?-
Re: cam button and spring
IIRC Hesco has them
sly-jeeper
I checked the website and couldn't find one, do I need to call or am I blind?
I got mine from the Jeep dealer, that was last fall?
sly-jeeper
I tried an online stealership
,.........do you have any other ideas I believe silver said something about just a machined pin to set the cam runout manually
sly-jeeper
My stroker is almost complete long block is assembled just missing the pin and spring, and the machine shop is finishing up the valve job =) by machine shop I mean a friend who builds race motors for a hobby. I ended up with a scat crank, resized rods, Mopar 229 cam, decked near zero, ic944 .030, stock felpro gasket, ported head with 60ish cc chambers .....9.6:1 @ 8.38 dynamic if I remembers
Yes, just replace the pin and spring with a solid pin. Set end play manually by cutting the pin until you get the desired end play.
sly-jeeper
Steel pin? Or should I use something softer?
Steel. You don't want soft against soft. Soft against soft = gauling.
sly-jeeper
Thanks
