Hi All,
Greetings from the UAE.
I would like to know if the two downstream o2 sensors affect fuelling.
I have no Cat and my rear two O2 sensors are absent (XJ 2001 4.7L).
Forums have two conflicting views:
The ECU:
1/ Takes into account rear 02 sensors for fuelling/ignition.
2/ Only uses it for cat efficiency.
I ask because the CEL is annoying me and I want to build a couple of 02 simulators to turn it off (have 138, 158 codes) - but I want to know if this would affect fuelling first.
Dave
Down Stream 02 Sensors
DesertDawg
- Vehicle Year: 2001
Re: Down Stream 02 Sensors
I haven't seen anything that indicates the rear sensors are there for anything but cat checking in anything with a 4.0L. Install the sims.
DesertDawg
Thanks Chris.
Dave
Dave
The signal from the upstream sensors is used by the ECU to adjust the A/F ratio for closed loop operation, while the downstream sensors monitor the function of the cats.
DesertDawg
Thanks Dino
