4.6 stroker stalling
turnbilljr
Stroker Displacement: 4.6l
Vehicle Year: 1994
Vehicle Make: Wrangler
Vehicle Model: Shara
Post by turnbilljr »
hey guys , having a problem with my stroker stalling . it doesn't do it all the time . sometime it stall at idle but will start back up. sometimes it will try to stall driving down the road at 60 mph. i have changed the crank senor and clean the air control on the throttle body. any ideas? :brickwall:
1994 Wangler YJ 4.6L Stroker
"eat ,sleep ,jeep.
Re: 4.6 stroker stalling
Does it stall when you are off the pedal? Or when you are on the pedal at a constant point?
turnbilljr
Vehicle Year: 1994
well at idle your foot is off the petal. it will stall , but starts back up. driving down the road its a even speed . not increasing speed but not decreasing speed. even speed. it try to stall ,but its like it stalls but picks back up .
"eat ,sleep ,jeep.
If the throttle is open and it stalls its not the IAC. Spark or fuel. How old is your coil and have you checked fuel pressure when this happens?
Is it a sputter and die or a quick cut off.
turnbilljr
Vehicle Year: 1994
i have a new Screamin' Demon Coil and DUI 4.0 LiveWires and Firepower Cap and Rotor. buy them when i build the stroker 4 months ago. as the fuel pressures goes am running 44 psi. i have the Hesco adjustable fuel pressure regulator. i haven't checked it running down the road. guess i need to hook up a fuel pressure gauge. i have change out the fuel pump a year ago but it was the cheap one at advance auto parts. thanks!!
"eat ,sleep ,jeep.
turnbilljr
Vehicle Year: 1994
well i checked the fuel pressures as i was driving down the road it runs about 44 psi . when the jeep stalls it stay around 40 to 44 psi. i did notice went it stalls out it wont start back . you have to turn the key off and back on then it will start right back up. seem like it all started went i put a alternator on the jeep. i had the OEM one on there but it was a 90 amp i was needing a high amp one . so i went to the junk yard on buy a 160 amp off of a 1997 grand Cherokee limited. i had it check before i put it on. they said it was good . so i put it on and it seam it work good 14.03 volts. do you think that could be causing the problem i am having???? :brickwall:
"eat ,sleep ,jeep.
I don't think the alt is the issue. Typically your voltage will drop very low first from a bad alt before cut off. I wouldn't completely eliminate it though. I would throw the stock one back on and see if it happens.
turnbilljr
Vehicle Year: 1994
thanks for the help !!! i will put the old one back on today and get it a try . i am guessing its a electrical problem?????
"eat ,sleep ,jeep.
turnbilljr wrote:i have a new Screamin' Demon Coil and DUI 4.0 LiveWires and Firepower Cap and Rotor. buy them when i build the stroker 4 months ago.
If you still have your old stock coil and it was good before you removed it, I suggest you reinstall it and see if the problem goes away. It's just possible that your nearly new Screamin' Demon Coil is no longer screaming, and I wouldn't rule out the possibility of your new crank sensor being a dud either. Try the coil first.
turnbilljr
Vehicle Year: 1994
you think it could be bad . i paid 174. for coil ,wires , cap , roto button. i hope it would last longer than 2000 miles. what kind of coil do you use? The coil you get at advance auto and auto zone are junk . they only last about a year. i have no luck with those.
"eat ,sleep ,jeep.
turnbilljr wrote:what kind of coil do you use?
I still have the 22-year-old stock original. :mrgreen:
turnbilljr
Vehicle Year: 1994
Hey Guys , well i change the alternator Saturday, put the original one back on. i haven't had any problems with it stalling . it runs really good . :banana: just wonder why it wont work? i guess it something breaking down in it. thanks for all your help !!!
"eat ,sleep ,jeep.
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Post by jbxx »
That's weird, I wouldn't think that the alternator would cause the symptoms that you were having.
turnbilljr
Vehicle Year: 1994
yep, me either. it sound crazy, but its run great. no stalling. :banana:
"eat ,sleep ,jeep.
turnbilljr
Vehicle Year: 1994
just a update on my stroker . all most 2 weeks now and it hasn't stall one time . running great !! :banana: thanks !!!
"eat ,sleep ,jeep.
