Installing fuel pressure gauge on the fuel rail?
Defcon92
Stroker Displacement: 4.2l
Post by Defcon92 »
I'm looking at installing a small fuel pressure gage onto my fuel rail of my 1992 cherokee however I'm unsure of the size of the nipple/shredder valve. I believe its a flared type fitting? Can anyone use there magical googling power and find the correct 90* elbow I'd need?
Would it be a female 1/8" flare fitting to a female 1/8" npt?
I'll be using this marshal 0-100 psi gauge which has a 1/8" npt fitting.
http://www.ebay.com/itm/Engine-Works-0- ... 4f&vxp=mtr
Re: Installing fuel pressure gauge on the fuel rail?
Do a search on here. I know there is at least one person that has done it. They used an adapter of some sort and IIRC removed the schrader valve.
shawnxj
I love this board
I love this board
Post by shawnxj »
i did that and i have to tighten it up regularly. it vibrates loose about every 500 miles. going to weld a female fitting on the end of the fuel rail this time and run it that way
RenoF250
Vehicle Year: 1985
Vehicle Model: CJ7
Post by RenoF250 »
This fitting takes the Schraeder to a gauge:
http://www.summitracing.com/parts/cei-107133/overview/
This gauge is cheaper and pretty nice:
http://www.summitracing.com/parts/sum-800199
The fitting does warn not to leave a oil filled gauge on or the vibrations will eventually crack the fuel rail. I just put mine on for diagnostics and then took it off. Also, the Schraeder side leaked until I used a few turns of the thick yellow teflon tape on it.
mark2215
Learning to use the board
Vehicle Year: 2005
Post by mark2215 »
I'm not sure if your fuel line connects to the fuel rail with the same connect or as me but this is what I used to isntall my fuel pressure sending unit.
http://www.summitracing.com/parts/NEX-16190
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
mark2215 wrote:I'm not sure if your fuel line connects to the fuel rail with the same connect or as me but this is what I used to isntall my fuel pressure sending unit.
That's a really nice piece, expensive, but nice.
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 1 guest
