99+ Timing Chain
jeepxj3
Vehicle Model: xj
99+ Timing Chain
Post by jeepxj3 »
What is a good replacement?
RockAuto has Ultrapower, EngineTech, DNJ, Cloyes, Sealed Power.
Which is the best quality?
Alexia
Vehicle Year: 1987
Re: 99+ Timing Chain
Post by Alexia »
I typically go with Cloyes part number C385.
Cloyes 9-3127 dual roller FTW.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
Cheromaniac wrote:Cloyes 9-3127 dual roller FTW.
Nice double roller set but it is for early blocks, 1964-1998 AMC/Jeep 6 cylinder engines and not for the '99+.
The correct PN for '99+ is Cloyes C3225. This is for the set- crank and cam sprockets and chain
Thanks, Cloyes it is.
Ordered from RockAuto $82.16 shipped.
Retlaw01XJ
Post by Retlaw01XJ »
Timing chain and gear choice for a 99-up depends on what cam you use. Cam/timing gear needs to be matched to the cam, not the block.
Most aftermarket cams will not work with the later cam retention plate and that style of cam/timing gear.
For my 2001, I also went with the 99-up Cloyes set, but later had to buy the correct early cam/timing gear after I decided to use a non-stock cam (Crower).
Walt K
Eastern Pa
There aren't many cams available for the 99+ cam w/ retaining plate. If you want something other than the usual earlier cam you will need to find a cam grinder that will work with you.
Tufiremn
Vehicle Year: 1999
Post by Tufiremn »
So what ya'll are saying is that if you run any cam but stock in a 99+, then you'll need to use a pre 99 cam bolt and button? I'm guessing the timing covers are the same. What about removing the rubber chain tensioner?
Jones Cams makes one that works with the retaining plate style. The chain snubber is up to you. Its on the tension side of the chain when it should be on the slack side. Also, some timing set need it and its mount removed.
