F.A.S.T. Injection for Jeep 4.0
str8-6
- I think I'll order a "tab"
- Vehicle Year: 2012
- Vehicle Make: Hot Rod
- Vehicle Model: T-27
I'm not sure if this has been covered here but I just found this: http://www.onallcylinders.com/wp-conten ... 0x1200.jpg
Jpross
- Learning to use the board
- Vehicle Year: 2006
Re: F.A.S.T. Injection for Jeep 4.0
Not sure what you are pointing out honestly without doing my own research. Whats up? It looks nice
str8-6
For a moment I tought that FAST had a new intake manifold of their own but when looking a bit closer it seems to be a stock one just for displaying their injection stuff.
BADASYJ
That doesn't look like a 4.0 intake at all. Looks as if it's a stock 4.2 intake. It would be much better suited on a intake designed for a four barrel carb.
4.2L carb intake. Throttle body injection. $1400? What a waste of money.
- Stroker Displacement: 4.9
Not even shiny........
Jpross
btw, I did research it... couldn't find much except this, advertising the throttle body for 4.2s. From what I can tell it converts a carb setup to fuel injection.
http://www.summitracing.com/search/prod ... ottle-body
The 4500 class guys from Colorado (Rants) use it on there Scrambler.
Heart of the system is a WB O2 that sends signals to a pre programmed ECU. Very limited amount of adjustability for both fuel and spark. The ECU is smart enough to keep the AFR in the "safe" zone. At least what it thinks is the safe zone. Beyond that, well..........
A JTEC set up with the right tune is far superior.
