Stroker eats gears
Rmcewe0
- Vehicle Model: Xj
Stroker eats gears
1998 XJ 4.6 stroker has started eating distributor gears,ran 3 years no problem, could my com cam be walking?
Re: Stroker eats gears
Are you running a HV pump?
Rmcewe0
- Vehicle Model: Xj
Yes I am running melling HV ,just pulled motor last night,when I have more free time will turn down and look for clues
What weight oil are you using?
Also, take a look and consider doing this modification: http://www.jeepstrokers.com/forum/viewt ... f=5&t=4715
Rmcewe0
- Vehicle Model: Xj
Well the com cam is junk crank needs polishing or turning ,rods and mains all junk, guess 3 years wheeling came to an end,as for my oil it was rotallia 15/30 maybe should do 5/20.
Rmcewe0
- Vehicle Model: Xj
Thanks for the pictures will do that while apart
