Hello everyone, I am building a 1974 javelin from the ground up and doing a custom build with the factory 258 inline 6. I'm doing the 4.0 efi swap and I am having trouble figuring out what year/model jeep my ecm came out of. It has been a long time since I pulled all the 4.0 efi items and can't remember the exact year or model of the jeep, although I want to say it was a 1999 cherokee sport. Hopefully you guys can help me out. I googled the ecm's part number: P56041 492AE and found an ebay ecm with the same part number that is listed for a 1999 cherokee, AT.
Can anyone confirm the year/model and if it is for an auto or manual transmission? Thanks!
ECM confirmation
1974javelin
- Vehicle Year: 1974
- Vehicle Make: AMC
- Vehicle Model: Javelin
1974javelin
- Vehicle Make: AMC
Re: ECM confirmation
Seems ECU is used more around here, that's what I'm talking about if there is any confusion.
jeepman
- Vehicle Year: 1989
- Vehicle Model: MJ
Yes the Factory Parts PDF I have shows it for a 99 although ending in a AC so AE is just a later release
1974javelin
- Vehicle Make: AMC
Thanks! I can narrow down what year wiring diagrams to look at now
Does anyone know if an automatic transmission ecu will work with a manual transmission? Or does this throw things off?
jeepman
- Vehicle Model: MJ
Yes you can run the auto computer with a Manual trans you just wont see the shift light and it might l throw a code or 2 but otherwise it will run and drive...
I ran a Manual Computer for my Auto for almost a year till I swapped out to a Auto Computer...
