rebuild kits
crazygogo
- Stroker Displacement: 242 + .30 over
- Vehicle Year: 2002
- Vehicle Model: wj
rebuild kits
what master rebuild kits did you guys here on jeep strokers get and how much? AND Is 1 better then anthers?
akadeutsch
- Vehicle Year: 1981
- Vehicle Model: CJ8
Re: rebuild kits
most of us pieced our kits together piece by piece. It is possible to save a lot of money this way
Re: rebuild kits
Check out Falcon on ebay.. might go by Falcon Global?
Found them: http://stores.ebay.com/Falcon-Sales-e-Store?rmvSB=true
crazygogo
- Vehicle Model: wj
Re: rebuild kits
thank you sliver xj.... Question? since more peace your kits together. has any one use the tri-metal crank bearing? and if so are they worth doing?
Retlaw01XJ
- Vehicle Year: 2001
Re: rebuild kits
Falcon is the internet division of 'Internal Engine Parts Group'SilverXJ wrote:Check out Falcon on ebay.. might go by Falcon Global?
http://www.internalengineparts.com/
They are a large volume parts distributor to machine shops and chain stores. Nine warehouses located in the SE USA area:
https://iep.qwik-order.com/WD/About/about.htm
You can call them and select which brands of components you want in your eBay engine kit.
The base package includes quality King bearings, but I went with the Clevites since I was more comfortable with that brand.
They had a great price on the ARP rod bolts too.
Walt K
Eastern Pa
Eastern Pa
