Header collector question for stroker
nicpaige
Vehicle Make: XJ
Vehicle Model: Sport
Post by nicpaige »
I have searched and have seen some people say so and so has a 2.5" collector but when I look up the actual part they advertise 2.125" as the largest. FlowTech advertises 2.500", does anyone have personal experience with these? I have used their stuff before and wasnt real impressed. Can someone name a brand other than FlowTech that has an actual 2.500" collector size? I will be using the Edelbrock head which advertises the pre 1999 exhaust port locations. Thanks
nicpaige
Vehicle Make: XJ
Re: Header collector question for stroker
Post by nicpaige »
Guess not :huh:
The thorley I am running has a 2.5" collector. but their adapter and donut gasket necks down to 2.125". I'm going to replace it with a standard 2.5" flange. However, I can't recommend Thorley's support.
mountaineerjeff
Stroker Displacement: 4.0
Vehicle Year: 1999
Post by mountaineerjeff »
I'm also gonna go with the "guess not" answer. I looked and couldn't find anything so I eventually had to get one of the available headers and I just modified it to run a full 3" setup.
build thread http://www.cherokeeforum.com/f46/offici ... ep-179516/
N/A 14.9@89
N2O 12.7@104
My Borla 17039 is 2.25" w/ s-pipe and the NOS Clifford single outlet header I recently picked up is 2.5"(I want to chop an inch off and weld on a 3" flange). I've read that the Pacesetter is 2.5", but is iffy on alignment/quality. You can also get Clifford's newer dual outlet header and they sell a y that merges it into a single 2.5" (maybe get a custom merge to 3"). Isn't the Banks revolver a 2.5" outlet?
embs2001
Vehicle Model: comanche
Post by embs2001 »
Where did you see pacesetter being 2.5? I read 2 inch collector which seems small. http://www.jegs.com/webapp/wcs/stores/s ... sce+setter
1988 Comanche w/ m90
Build thread- http://www.naxja.org/forum/showthread.php?t=1118735
nicpaige
Vehicle Make: XJ
Post by nicpaige »
I assumed the PaceSetter header was two 2" collectors then into one ? pipe. That dual slip on pipe feature looks like an exhaust leak nightmare to me.
mountaineerjeff
Vehicle Year: 1999
Pacesetter is what I started with.
N/A 14.9@89
N2O 12.7@104
embs2001
Post by embs2001 »
Is the final collector bigger than the middle two? 2.5 inch?
nicpaige
Vehicle Make: XJ
Post by nicpaige »
mountaineerjeff wrote:Pacesetter is what I started with.
The end collector on that does look bigger than the other two. Was it possible mountaineerjeff to install that header with the pipes welded like that? That would solve the leak issue.
6TIME
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
I'm running a Gibson Revolver stainless header and it measured 2.5" at the outlet pn 51327. Looks like some sources have it listed at 2" but that's incorrect.
mountaineerjeff
Vehicle Year: 1999
Installed...after I welded a 3" flange for true full 3".
N/A 14.9@89
N2O 12.7@104
beater_renix
Vehicle Year: 1989
Post by beater_renix »
Captain Obvious here: You can save time and money when setting up your new header by making sure your down pipe and front drive-shaft don't occupy the same space.
-Awesome Quote...
Beater_Renix
the_wrench116
Post by the_wrench116 »
old news but I did this years ago. and it still works great. it would be easy enough to make another one as I still have the spare engine and transmission.
