oil pan q's
myillwillinc
oil pan q's
Post by myillwillinc »
is the 4.2 center style sump better/worse then the 4.0 rear sump? it seems they can be swapped either way if you have the correct pickup tube. what is everybodys thoughts on this?
Re: oil pan q's
They are designed to fit a particular chassis, as is the exhaust, and most of the bolted on accessory's for that matter.
myillwillinc
Re: oil pan q's
the 4.2 I got came from a 85cj the 4.2 in my 90yj has the rear sump pan.
