Putting a '98 ZJ 4.0 into my '85 CJ7. Using a '98 PCM from a manual XJ with the PDC and wiring harness that came with the engine. Used an FSM and traced the wires to verify and make connections. Neutral safety switch is grounded along with the BK/TN ground wire.
Used the Hesco CPS relocation kit. Cut the connectors off of engine harness and CPS and spliced them together. Ran the three wires up and around the intake and along the wiring/fuel rail. Have tried the CPS sensor in different distances off of the harmonic balancer. Starter engages, fuel pump kicks on and I have fuel at the rail but no spark or fire.
I've searched a lot and it appears the biggest culprit is the CPS Sensor wiring or location. I'm guessing I have the wires connected wrong. I used the connector layout comparison between the engine harness and CPS to determine which wires related to which since the CPS didn't have color coding except for the center which has a white stripe. I read somewhere that this is suppose to be ground?
I would have bought the connector Hesco sells but it no longer has color coding either. They don't sell the CPS wire connection extension anymore. Anyone know how to determine which wire is for which?
If I buy the CPS Sensor from a parts store that is similar in profile but has the wiring coding, will it work with the Hesco damper?
Hesco CPS Issue
Neuner
- Learning to use the board
- Vehicle Year: 1985
- Vehicle Model: CJ7
Hesco CPS Issue
Things you own, begin owning you.
beiwulf
- Vehicle Year: 1995
- Vehicle Make: ZJ
- Vehicle Model: Laredo
Re: Hesco CPS Issue
I have not done this relocation yet. Watching thread for tech posted. I am more then certain we have a few guys who have done this and know. Good question and appreciate the posting. I'll look into what I have avialable. What are the colors of the wires the relocation sensor has, and do you have a pic of where they go into the cps?
I do know the CKP sensor on flywheel/flexplate is located about 2 o'clock and the hesco relocation one is located 3 o'clock.
Brian
Brian
beiwulf
- Vehicle Make: ZJ
Re: Hesco CPS Issue
post #9 - similar wiring issue - called hesco.
Not sure but here is another thread referencing - but no wire diagram color reference.
http://www.jeepsunlimited.com/forums/sh ... -OEM/page1
Neuner
Re: Hesco CPS Issue
I had contacted Hesco and all they did was send me a pic essentially saying, figure it out yourself however I was able to layout my wires to resemble the photo and note that I had the outer two wired incorrectly. I set mine 0.025 from the dampener surface. Once I got it re-wired, it fired right up.
The pic they sent is a PDF and I'm not sure how to attach it. I found a similar photo online and have attached it.
I did find out that a CPS, that has the same attachment style as the one they include, that is for your year 4.0 will work. If I couldn't figure it out, I was going to drop by a local parts store and pick one up which had the correct connector and wire coding. For as much as they charge you'd think they could at least provide you with the right connection or wire codes.
Hope this helps.
Hope this helps.
beiwulf
- Vehicle Make: ZJ
Re: Hesco CPS Issue
I will have some wiring diagrams this weekend to review for my project. 1995(zj) and the 2000(wj) wiring diagrams - I'll check and see what they have referenced for it. That is if someone else doesn't resolve this with reply first.
B
B
beiwulf
- Vehicle Make: ZJ
Re: Hesco CPS Issue
