Crack in bottom of cylinder bore
PseudoSport
Stroker Displacement: 4.0L Turbo
Vehicle Year: 1995
Post by PseudoSport »
I’m working on refreshing my friends stroker engine that’s been sitting on a stand for 5 years. We tore it all down to, cleaned it up, and honed the cylinders with a ball hone. After a final cleaning we noticed that 2 cylinders had cracks at the bottom along a casting parting line. The crack stops when it gets to thicker metal below the lifters. It doesn’t go into a coolant passage and is 1” long. The block is a Renix that’s been bored .060 over. Walls were sonic check before the overbore to make sure they were thick enough. Has anyone else seen this?
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
6TIME
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Re: Crack in bottom of cylinder bore
Post by 6TIME »
I had a 93' HO 4.0 block with about 200k on it do that (1/2' long hairline crack )slightly higher up where #'s 3-4 were siamesed. It acted like a blown HG once warm. Milled head and new HG, fired it up.... Blew the coolant out the radiator when warm again?? Tore it down and found a tiny line above the piston at BDC, looked like a piece of lint on the cylinder. Took a pick tool and scraped at it, sure enough it was a crack in #3. Odd for sure.
Magnaflux it, if it is below the water jacket and the lifter boss drill the end of it to stop the crack.
IH 392 wrote:Magnaflux it, if it is below the water jacket and the lifter boss drill the end of it to stop the crack.
It's a $100.00 Jeep block not a 15k Lamborghini block.
If you want to mag and pressure test it that's fine, but the upside of trying to repair it compared to the downside
of havin water in your oil later isn't worth it.
My .02
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Post by I6FAN »
What's up with the recess where the cylinder bore meets the block and the "scallops"? Back wall looks extremely "grainy"; probably full of porosity. I would get another one I think this is a bad casting.
Even if the crack is below the water jacket now, there's a risk the crack will extend higher after a few heat cycles so I'd scrap that block and start over. It seems the 0.060" overbore found the limit of that block.
