supercharger
vashxj
Vehicle Year: 1999
supercharger
Post by vashxj »
ok so im about to finish up getting my s/c all done got the v1 mounting bracket made I just have to measure the belt, hook up the oil lines, change injectors and map sensor. then just get it all tuned. so my question is for you guys that have forced induction already is there anything im missing? like having to put in vac check valves or anything. im thinking I will have to change the pcv system and put a catch can. any help would be appreciated im going on the hot rod power tour on june 6 so im trying not to miss anything.
jeepxj3
Vehicle Model: xj
Re: supercharger
Post by jeepxj3 »
I thought you were stroker and using nitrous? Now supercharger? Any pics? More SC info?
SIXPAK
Stroker Displacement: 280
Re: supercharger
Post by SIXPAK »
Boost referenced fuel presuure reg?
vashxj
Vehicle Year: 1999
Re: supercharger
Post by vashxj »
Well the whole plan was a s/c I just came across the nitrous kit cheap, I will be bumping it down to 75 shot now and I have obd2 so the regulator is not a problem
jeepxj3
Vehicle Model: xj
Re: supercharger
Post by jeepxj3 »
Regulator is in the tank and returnless fuel line.
