JTEC idle control illustrated and explained
christuned
Learning to use the board
Post by christuned »
Sidewaysstarion and I have put together this little video to help people understand how JTEC idle control works on your Jeep. More specifically we perform a minimum air flow test (which is normally done with a DRB3). I've seen so many people post on this forum, pleading for help while trying to diagnose their own vehicle, with absolutely no or very little understanding of what is happening. A lot of helpful people with some experience give advice, and usually there is a lot of time spent, a lot of parts changed, and more often than not the problem is not resolved.
I think it's great to share information, and help fellow Jeep people. However, if you are not willing to invest the time and effort to understand why your Jeep is not working correctly, then I is my opinion you should not be attempting to diagnose and repair your vehicle. I've seen many instances where people have spent a considerable amount of time(=money) and thrown many parts at their Jeep trying to fix a simple issue. This is not the way to fix a problem, either understand what's going on, get the proper tools to diagnose your Jeep or have a professional fix it for you, it will cost you less money in the end.
Besides the video, we have included the two log files of the data that is shown in the video, that can be viewed in either AEMData or AEMLog.
right click and save as below:
AEM Data Template
Before throttle body cleaning
After throttle body cleaning
AEM Log parameters
AEM Data Installer
AEM Log Installer
OBD1 and OBD2 Jeep tuning (Renix, SBECII, JTEC, JTEC+, NGC) , re-programming via handheld programmer or bench flash.
Live mapping available using ecu memory emulation and high speed SCI logging.
Expert DCX tuning for over 9 years.
nicpaige
Vehicle Make: XJ
Vehicle Model: Sport
Re: JTEC idle control illustrated and explained
Post by nicpaige »
Cool video, I will be testing that out asap for my low idle issue. Thanks Chris.
