Jeep Timing Table
1scram
- Stroker Displacement: 282
- Vehicle Year: 1981
- Vehicle Model: cj8
Jeep Timing Table
I have been working on tuning and have built a stock jeep timing table based on "Base + Mech + Vacuum" and thought I would share the information. The table is base on max advance.
xdark
- Vehicle Model: wrangler
Re: Jeep Timing Table
Ive been running the AEM F/IC 6 piggyback for a few weeks now . its not too bad . im surprised no body is interested in fuel maps and ignition timing.
Brammudje
- Stroker Displacement: 4,7
- Vehicle Year: 1984
- Vehicle Model: CJ7
Thanks!
stroked'73
- Vehicle Year: 1973
- Vehicle Model: Wagoneer
I 've been using your table to get a kindof baseline for my carbureted / vacuum distributor setup. I know there's so many variables like CR's and such, but do you think the info in your table is transferable to a non-efi/computer controlled setup?
I too have looked pretty hard for timing info for these strokers and have come up empty. Maybe cause the ECM's do all the thinking and adjusting?
Anyway, I was stoked to find your table last year and appreciate you sharing it. Saw that it was ressurected so I thought I'd ask!
Tucker.dt
- Vehicle Year: 1982
- Vehicle Model: Cj7
Brianj5600
- I think I'll order a "tab"
- Vehicle Year: 2004
Load is in torr. You will have to convert to kPa, Psi, etc.
Stock timing in my 2004 TJ.
What I run with my 2004 TJ.
darkcorp
- Vehicle Year: 1999
- Vehicle Make: JEEP
- Vehicle Model: GCh 4.0
Brianj5600, thanks a lot!
What is torr?
What is torr?
- Vehicle Make: Jeep XJ
