wide band O2 sensor
Zorm
Vehicle Year: 1983
wide band O2 sensor
Post by Zorm »
Ok, since I am going to use a wide band sensor along with the stock O2 sensor, would I mount it above or below the stock one?
Re: wide band O2 sensor
It doesn't matter as long as it is close enough to the engine.
jeepxj3
Vehicle Model: xj
Post by jeepxj3 »
I've seen the dyno guys mount their wide band in the tail pipe while dyno tuning. How much does it matter, if any?
jeepxj3 wrote:I've seen the dyno guys mount their wide band in the tail pipe while dyno tuning. How much does it matter, if any?
It's less accurate when mounted in the tailpipe and might read leaner than the engine actually is.
